9012 remote for 9088 (non ii)
Can some one please tell me whether a SW-9012 remote can be used to control a 9088 (non ii)?
Also, are there any operational differences between the US model and the UK model 9012 units?
No.
Dan
Andew
One thing to be aware of, if you use 9012 remotes on the same gain stage, as the 9012 uses a 50k pot, the control ports will reference the last used remote control, meaning the 2 remotes will go out of sync.
If you want both remotes to reference the same gain stage, you need to use a 9015 as it uses up/down buttons, meaning that if you use one remote, the other one will 'take over' where the previous one left off.
A 9015 uses 3 ports (Up, Down, source/preset select) so a total of 2 can be used per device.
Enjoy
Rob
I'll settle for one 9012 either at the rack or in the wall.
Cheers
