Setting Input Types on 3088
I am trying to upload a new control program into the soundweb. I keep getting the following message:
The following devices have the wrong options set :-
* Name : Studio B Type : 3088 DSP
'Input 1-4' is set up as 'Mic Input' in design,
but as 'Line Input' on network device.
How can I change the network device to 'Mic Input' on ' Input 1-4'?
Change it to suit (Input 1-4 from mic to line). OK out of the properties menu.
Go back online. load all, job done.
Cheers
Rob
I just tried that again but I get the same message and do not get the option to load anything in the network window. Any reason why it will not let me load the new input setting over the old one?
Dan
In this tabbed option menu, you will find one page that relates to the units Input configuration. Change it so that the design matches the network hardware. (from mic to Line).
OK out of the menu.
Go to the network window, select 'go online' . Designer should go online and find the 'studio B' device and say that it needs to be loaded.
Load the device with your offline design file, and make beautiful noise.
Hope this is clearer.
Rob
