adding a crossover
I am trying to add a crossover to my signal path so that I can feed a seperate subwoofer. When I add the crossover to the architect file and connect the input source from the input card and connect the output to the output card I do not get any output signal. Yet if I add a mixer and create different groups and place a filter in the signal path I can get signals from the output card. Is there something that needs to be done in order to get the crossover to function. I have set the crossover output 1 to low pass 80Hz.
Dan
Thanks.
Barry
