Manual
I went through the certification and passed, but now that I'm facing my first design, I'm a bit nervous without a manual to reference as I start building the project. Is there such a thing? This may have been asked already but I couldn't find an answer here anywhere.
I will start with the Application design for an 8 room hotel conference room, but will need to make some changes (would like to use the BLU-8 to allow room combining with the four buttons). Anyway, any help or advice would be greatly appreciated.
Scott
  • Hi, and congratulations on passing!!
    There is an extensive help file included in the program. Press F1 at anytime and use the search item to query what you want to know.
    Apart from that there are the Flash modules that you may or may not have downloaded from the training section as part of your certification process.
    There are the 11 application files in this forum that you can use as a basis for your designs.
    There is not a specific print out of what to do when presented with a new design file as the design options are pretty much 'whatever you want'.
    Dependant how many designs you do, if there is a particular processing object or combination you use, it may be worthwhile making a macro for this so that your design time is reduced.
    I make extensive use of the gallery, as most of my time is spent creating navigation on custom pages and placing mixers. I also use it to store text strings that i regularly use.
    I am unsure what other help and advice you are after, so if you have any specific 'how do I' questions post them here, or if it is time critical get in touch with your local BSS support agent.
    ( Oh, and yes you can use a BLU8 to room combine. )
    Cheers
    Rob
