Reorder items in the Design view?
I have a design with a great many presets, these presets where created on the fly at the request of the customer. As such they are in not in any inteligable order. Is there a way to reorganize them so that when using the rotary on the blu-10 the presets will come up in a logical order as opposed to the order in which they where stored?
For example, if you have five presets you recall the one you wish to be the first and save it as a new preset, number six. Repeat for the rest. When you're done, simply delete the five \"old\" presets and what is left are the five \"new\" in the right order.
/Chris
The answer to your original question is, \"no\".
Dan
I was actually just about to ask the same question when I found this post. Is this something that could be added in the next version? Some way to manually edit the preset IDs would also be useful.
Anders Haggblom
Kainos Media
Finland
2) you have to be using external serial control to trigger those presets
3) you have to have done all of your serial programming before you decide to fix the original mess
Not very many people will meet all three of those criteria. For everyone else, it's not that big of a deal.
The other things already on the wish-list are a lot cooler and apply to a much larger number of users.
Dan
Create your required parameter presets. Use these parameter preset numbers to reference presets in the third part control software.
You can now place a preset trigger or preset trigger table downstream of the logic sources. Place your audio presets into these preset triggers. You can reorder them as required without having to modify the third party code.
Cheers
Rob
