Home BSS Forum BSS Software & Programming
Recover design file from sw9088iis
Hello,
I work in a bar and we would like to adjust some of the processing done by our DSP (sw9088iis) however it was installed a longtime ago and no-one has the design file. If I connect to the device and load up the soundweb designer software will I be able to control it without having the design file? If not is it possible to recover the file from the device? All I can work out from the documentation is that it will appear in the "not found in design" column when I go online.
Thanks in advance,
Ryan
