Clearone SR1212 ADPRESENT command
Hi,
Does anybody have any experience with the ClearOne SR1212 ADPRESENT command? I'm receiving responses from the SR1212 but what I'm receiving is different from what the manual is saying I should.
Here are 3 responses back from the SR1212
#G3 ADPRESENT 0 6 0 0 0$0D$0AOK>
#G3 ADPRESENT 0 E 0 0 0$0D$0AOK>
#G3 ADPRESENT 0 FEF 0 0 0$0D$0AOK>
The command is on page 239 of the serial control manual.
Any Thoughts?
Yours,
John Wilhelmi
  • cmatkin
    cmatkin Senior Member
    Hi jwilhelmi,
    The ADPRESENT will report back the following:
    DEVICE ADPRESENT INPUTS OUTPUTS PROCESS FADERS TELCO
    EG:
    Output 6 has a signal
    Outputs 2,3,4 have signals
    Outputs 1-4 and 6-12 have signals
    Hope this helps.
    Cheers
    Craig
  • jwilhelmi
    jwilhelmi Junior Member
    ADPRESENT
    cmatkin wrote: »
    Hi jwilhelmi,
    EG:
    Hope this helps.
    Cheers
    Craig
    In the first statement if Hex 6 is converted back to binary, the result would turn on bits 2 &3.
    for the string,
    would read
    Outputs 2&3 have a signal
    Was there something in the math that I missed?
    John
  • cmatkin
    Hi John,
    No, you are correct.
    Sorry, I don't know what happened.
    Cheers
