Odd Video Switching Issue with DVX
Just ran into an odd issue with a DVX-2155 and was wondering if anyone had seen anything similar. I'm switching by using send_levels to the various device ports and for some reason output 2 is not always switching when the level changes (ie the level shows a value of two but there is no video on the output and the web interface shows no input switched to output 2)
  • shr00m-dewshr00m-dew Junior Member
    Are you switching multiple outputs when this happens? I'm using send_levels to control a couple of 3150's and have noticed that without a delay between commands, it doesn't always switch right.
    Kevin D.
