Best Serial/TCP/IP Terminal softwares
I just want to know which softwares are popular to be used with your laptop for Serial/TCP/IP terminal purposes. I heard of putty, tera term, Hercules. Any thing else worth mentioning or better than all.
And make custom command libraries for each device type, AMX, Cisco IOS, Unix, etc. it also allows you to define variables and use them in the library command entries.
It's free and has some interesting features, esp. if you are frequently connecting to multiple servers at the same time.
http://www.docklight.de/udp_tcp_info.htm
What I like:
It can load/store for every device a device specific command file and log file in Hex/Ascii/Decimal/Binary.
Also repeat command is useful for testing long cable runs when you are alone.
€ 59,- Docklight, RS232 only
€ 118,- Docklight Scripting, RS232 and TCP/UDP
I've used RealTerm for years.
