Need help with Autonomic MMS-2 module
I am working on a project and first time programming Autonomic MMS-2. I am using the module from their website but how do you initiate the connection to the server? There was no help document with the module and I am confused at this point. I saw that ON channel event on the vdv is what triggers the connect command. I turned it on in define start of my main program and it did nothing. Any help is appreciated.
Just paste your code here between a code marker like this
