Synology Surveillance Station
I just came across a WEB API for the Synology NAS Surveillance Station app that allows you to control almost all features of the NVR. You can get all your cam info, control recording, view schedules, retrieve stored files, etc.
Here's a little of the info you can pull off it with some of the available queries, it also shows the string to start recording camera 1. This should help anyone that might want to use one of these figure out how to go about doing this.
http://download.synology.com/download/ds/userguide/Synology_Surveillance_Station_Web_API_v0.12.pdf
      3 (08:07:46)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line      4 (08:07:46)::  Connected Successfully
    Line      5 (08:07:46)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line      6 (08:07:46)::  CIpEvent::OnLine 0:12:1
    Line      7 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 1 ] :DEBUG<293>
    Line      8 (08:07:47)::  Exiting TCP Read thread - closing this socket for local port 12
    Line      9 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ {"data":{"SYNO.API.Auth":{"maxVersion":3,"minVersion":1,"path":"auth.cgi"},"SYNO.Survei
    Line     10 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-2], llanceStation.AudioStream":{"maxVersion":1,"minVersion":1,"path":"SurveillanceStation/audioStreaming
    Line     11 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-3], .cgi"},"SYNO.SurveillanceStation.Camera":{"maxVersion":3,"minVersion":1,"path":"SurveillanceStation/
    Line     12 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-4], camera.cgi"},"SYNO.SurveillanceStation.Device":{"maxVersion":2,"minVersion":1,"path":"SurveillanceSt
    Line     13 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-5], ation/device.cgi"},"SYNO.SurveillanceStation.Emap":{"maxVersion":1,"minVersion":1,"path":"Surveillan
    Line     14 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-6], ceStation/emap.cgi"},"SYNO.SurveillanceStation.Event":{"maxVersion":2,"minVersion":1,"path":"Surveil
    Line     15 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-7], lanceStation/event.cgi"},"SYNO.SurveillanceStation.ExternalRecording":{"maxVersion":2,"minVersion":1
    Line     16 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-8], ,"path":"SurveillanceStation/extrecord.cgi"},"SYNO.SurveillanceStation.Info":{"maxVersion":2,"minVer
    Line     17 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-9], sion":1,"path":"SurveillanceStation/info.cgi"},"SYNO.SurveillanceStation.Notification":{"maxVersion"
    Line     18 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-10], :1,"minVersion":1,"path":"SurveillanceStation/notification.cgi"},"SYNO.SurveillanceStation.PTZ":{"ma
    Line     19 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-11], xVersion":2,"minVersion":1,"path":"SurveillanceStation/ptz.cgi"},"SYNO.SurveillanceStation.Streaming
    Line     20 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-12], ":{"maxVersion":2,"minVersion":1,"path":"SurveillanceStation/streaming.cgi"},"SYNO.SurveillanceStati
    Line     21 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-13], on.VideoStream":{"maxVersion":1,"minVersion":1,"path":"SurveillanceStation/videoStreaming.cgi"}},"su
    Line     22 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-14], ccess":true}$0A ] :DEBUG<1623>
    Line     23 (08:07:47)::  CIpEvent::OffLine 0:12:1
    Line     24 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line     25 (08:07:47)::  Connected Successfully
    Line     26 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line     27 (08:07:47)::  CIpEvent::OnLine 0:12:1
    Line     28 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 2 ] :DEBUG<293>
    Line     29 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send String-[ GET /webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=2&account=username&p
    Line     30 (08:07:47)::  SynSS MOD-[ 1 ] DEBUG:[L-2], asswd=mypassword&session=SurveillanceStation&format=sid$0D$0A ] :DEBUG<315>
    Line     31 (08:07:47)::  UI DEBUG: (1) [ 10003:1:0 ], PUSH CHNL-[ 101 ] :DEBUG<5492>
    Line     33 (08:07:48)::  Exiting TCP Read thread - closing this socket for local port 12
    Line     34 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ {"data":{"sid":"x5TbSqVz66DWg"},"success":true}$0A ] :DEBUG<1623>
    Line     35 (08:07:48)::  CIpEvent::OffLine 0:12:1
    Line     36 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line     37 (08:07:48)::  Connected Successfully
    Line     38 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line     39 (08:07:48)::  CIpEvent::OnLine 0:12:1
    Line     40 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 3 ] :DEBUG<293>
    Line     41 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send String-[ GET /webapi/SurveillanceStation/camera.cgi?api=SYNO.SurveillanceStation.Camera
    Line     42 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-2], &method=List&version=1&offset=0&limit=4&additional=device,video,record,schedule,advanced&_sid=x5TbSq
    Line     43 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-3], Vz66DWg$0D$0A ] :DEBUG<323>
    Line     44 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ {"data":{"cameras":[{"additional":{"advanced":{"liveSource":1,"mdSource":1,"rotationLim
    Line     45 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-2], itReachedAction":0},"device":{"channel":"1","httpPort":80,"model":"213 PTZ","vendor":"AXIS"},"record
    Line     46 (08:07:48)::  Exiting TCP Read thread - closing this socket for local port 12
    Line     47 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-3], ":{"eventFolder":"/var/services/surveillance/Hooker Cam","eventPrefix":"Hooker Cam","postRecTime":15
    Line     48 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-4], ,"preRecTime":5,"recTime":30,"rotationDay":0,"rotationSize":250},"schedule":{"fri":[2,2,2,2,2,2,2,2,
    Line     49 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-5], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"mon":[2,2,2,2,2,2,
    Line     50 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-6], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"sat":[2,2,2,2,
    Line     51 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-7], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"sun":[2,2,
    Line     52 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-8], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"thu":[
    Line     53 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-9], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"tu
    Line     54 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-10], e":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2]
    Line     55 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-11], ,"wed":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,
    Line     56 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-12], 2,2]},"video":{"liveFps":30,"liveQuality":"5","liveResolution":"4CIF","recFps":30,"recQuality":"5","
    Line     57 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-13], recResolution":"4CIF","streamingType":"HTTP","videoCodec":"MJPEG"}},"enabled":true,"host":"192.168.1
    Line     58 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-14], .42","id":1,"name":"Hooker Cam","recStatus":0,"status":0},{"additional":{"advanced":{"liveSource":1,
    Line     59 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-15], "mdSource":1,"rotationLimitReachedAction":0},"device":{"channel":"1","httpPort":80,"model":"209FD","
    Line     60 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-16], vendor":"AXIS"},"record":{"eventFolder":"/var/services/surveillance/Porch Cam","eventPrefix":"Porch
    Line     61 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-17], Cam","postRecTime":15,"preRecTime":5,"recTime":30,"rotationDay":0,"rotationSize":250},"schedule":{"f
    Line     62 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-18], ri":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2
    Line     63 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-19], ],"mon":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2
    Line     64 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-20], ,2,2],"sat":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2
    Line     65 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-21], ,2,2,2,2] ] :DEBUG<1623>
    Line     66 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ ,"sun":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2, ] :DEBUG<1623>
    Line     67 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"thu":[2,2,2,2,2,2,2,2,2,2,2,2,2,2
    Line     68 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-2], ,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"tue":[2,2,2,2,2,2,2,2,2,2,2,2
    Line     69 (08:07:48)::  SynSS MOD-[ 1 ] DEBUG:[L-3], ,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"wed":[2,2,2,2,2,2,2,2,2,2
    Line     70 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-4], ,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2]},"video":{"liveFps":30
    Line     71 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-5], ,"liveQuality":"5","liveResolution":"640x480","recFps":30,"recQuality":"5","recResolution":"640x480"
    Line     72 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-6], ,"streamingType":"HTTP","videoCodec":"MJPEG"}},"enabled":true,"host":"192.168.1.52","id":2,"name":"P
    Line     73 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-7], orch Cam","recStatus":0,"status":0},{"additional":{"advanced":{"liveSource":1,"mdSource":1,"rotation
    Line     74 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-8], LimitReachedAction":0},"device":{"channel":"1","httpPort":80,"model":"241S","vendor":"AXIS"},"record
    Line     75 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-9], ":{"eventFolder":"/var/services/surveillance/Parking Cam","eventPrefix":"Parking Cam","postRecTime":
    Line     76 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-10], 15,"preRecTime":5,"recTime":30,"rotationDay":0,"rotationSize":250},"schedule":{"fri":[2,2,2,2,2,2,2,
    Line     77 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-11], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"mon":[2,2,2,2,2,
    Line     78 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-12], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"sat":[2,2,2,
    Line     79 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-13], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"sun":[2,
    Line     80 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-14], 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"thu"
    Line     81 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-15], :[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2],"
    Line     82 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-16], tue":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,
    Line     83 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-17], 2],"wed":[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,
    Line     84 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-18], 2,2,2]},"video":{"liveFps":30,"liveQuality":"5","liveResolution":"4CIF","recFps":30,"recQuality":"5"
    Line     85 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-19], ,"recResolution":"4CIF","streamingType":"HTTP","videoCodec":"MJPEG"}},"enabled":true,"host":"192.168
    Line     86 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-20], .1.54","id":3,"name":"Parking Cam","recS ] :DEBUG<1623>
    Line     87 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ tatus":0,"status":0}],"offset":0,"total":3},"success":true}$0A ] :DEBUG<1623>
    Line     88 (08:07:49)::  CIpEvent::OffLine 0:12:1
    Line     89 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line     90 (08:07:49)::  Connected Successfully
    Line     91 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line     92 (08:07:49)::  CIpEvent::OnLine 0:12:1
    Line     93 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 4 ] :DEBUG<293>
    Line     94 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send String-[ GET /webapi/SurveillanceStation/extrecord.cgi?api=SYNO.SurveillanceStation.Ext
    Line     95 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-2], ernalRecording&method=Record&version=1&cameraId=1&action=start&_sid=x5TbSqVz66DWg$0D$0A ] :DEBUG<331>
    Line     96 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ {"data":{"success":true},"success":true}$0A ] :DEBUG<1623>
    Line     97 (08:07:49)::  Exiting TCP Read thread - closing this socket for local port 12
    Line     98 (08:07:49)::  CIpEvent::OffLine 0:12:1
    Line     99 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line    100 (08:07:49)::  Connected Successfully
    Line    101 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line    102 (08:07:49)::  CIpEvent::OnLine 0:12:1
    Line    103 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 5 ] :DEBUG<293>
    Line    104 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send String-[ GET /webapi/auth.cgi?api=SYNO.API.Auth&method=Logout&version=1&session=Surveil
    Line    105 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-2], lanceStation&_sid=x5TbSqVz66DWg$0D$0A ] :DEBUG<339>
    Line    106 (08:07:49)::  Exiting TCP Read thread - closing this socket for local port 12
    Line    107 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], String, RX-[ {"success":true}$0A ] :DEBUG<1623>
    Line    108 (08:07:49)::  CIpEvent::OffLine 0:12:1
    Line    109 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ], Attempting IP_Open :DEBUG<218>
    Line    110 (08:07:49)::  Connected Successfully
    Line    111 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Connected to SynSS MOD-[ 1 ], host IP-[ 192.168.1.45 ] :DEBUG<264>
    Line    112 (08:07:49)::  CIpEvent::OnLine 0:12:1
    Line    113 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], Online, Send Command-[ 6 ] :DEBUG<293>
    Line    114 (08:07:49)::  SynSS MOD-[ 1 ] DEBUG:[L-1], fnDevMod_IPClose: Closing connection! :DEBUG<283>
  • mludviksenmludviksen Junior Member
    Hi Vining,
    I'm curious about Synology Surveillance Station myself... Do you have the IP cameras on a VLAN so that they don't clog up everything else? It seems to me that the perfect situation would be to put a Synology on a dedicated network switch with all IP cameras, and then send the video stream to the AMX panels from the Synology - is that how it's done? Or, do you have to stream the video from the cameras to both the Synology and the AMX panels at the same time on the same network? I'm a little concerned about network bandwidth...
    Mark
