Odd structure "bug"
a_riot42
AMX Wizard
I noticed the other day that the compiler doesn't care if you declare a structure type without defining it. In define_variable you can put:
and even though there is no _Fubar in define_type, the compiler doesn't care. Rather odd.
Paul
volatile _Fubar fubar
Paul
I talked to Mark Gillner, AMX Canada Trainer, and he figures the compiler will
simply ignore fubar and _Fubar will be an Integer.
compiler interprets to
VOLATILE Integer _Fubar; -
Paul
There is no structure type involved here.jdonachiue@shaw.ca wrote: »I talked to Mark Gillner, AMX Canada Trainer, and he figures the compiler will
I don't think that is true.
I think the compiler will see _Fubar as a VOLATILE INTEGER
and
the compiler will see fubar as a NON_VOLATILE INTEGER
Edit:
To further clarifyDEFINE_VARIABLE volatile _Fubar fubar
Will be seen as:DEFINE_VARIABLE volatile _Fubar // defaults to INTEGER fubar // defaults to NON_VOLATILE INTEGER
Yes the compiler must see it as an integer. Without the structure in define_type it has no way of knowing you are trying to declare a structure rather than a default integer. I had a typo in my structure declaration and was surprised that the compiler didn't complain, but what you say makes perfect sense.
Paul -
Ah yes, that makes perfect sense.
DEFINE_VARIABLE
Thank you for the clarification.
