IP COMM ?
vining
X Member
I'm in the middle of updating one of my modules which uses IP comms. Originally I opened a socket and maintained it but I decided it might be nicer if I turned off unsolicited feedback from the device and closed the socket (IP_CLIENT_CLOSE) when the device isn't actually playing (music server) and no UI's are on that device/instance page. Simple enough, right but when I close the connection I can't re-connect and get an IP error "connection refused" when I attempt to re-connect (going back to the device page). My code will continually attempt to connect, first every 30 seconds and if that doesn't work after 5 attempt it tries every 5 minutes indefinitely but it never connects. If I do another IP_CLIENT_CLOSE it will throw an error "port already closed". In order to connect I have to reboot either the server or the master, so I typically choose the master since it's faster.
So the question is, if rebooting the master allows me to connect is it a problem with the master or the server? If the ports closed which it is and if I send IP_CLOSE again to confirm it lets me know how can rebooting the master fix the issue unless it is the master holding on to something. If there's no connection to drop during the reboot how could that clear up an issue with the server holding on to something and not allowing the re-connect? What ever it is doesn't time out either.
I've been looking at IP_BOUND_CLIENT_OPEN but I'm not sure how one would determine what local port isn't in use to use plus I would tend to think that if the problem is in this realm it's the master trying to re-use the previous assigned local port and the device want anything but that and that's what the reboot clears so bounding would be the last thing I should do.
Any thoughts/ideas?
Any thoughts/ideas?
Paul
Sounds like its time to start Wireshark. Post the results if you do.
Paul
I came across a similar issue when I wanted to check if the internet was available or not and opened up a port to google. If the internet was live, everything was ok. If not, there was an issue - the port wasn't open and it wasn't closed, it was somewhere in between and never timed out so I couldn't close it or try to reconnect - very bizarre.
In your case its a bit odd because you would have thought that it would simply cut off and allow reconnection.
Wouldn't it be easier to just turn off the feedback using a 'selection array' which only allows feedback through when the panel is active in the selection array?
Duncan
DEFINE_FUNCTION fnDevMod_IPBoundOpen() { LOCAL_VAR INTEGER nLast_Local_Port; if(sSBS.sPlayer.nIP_ConState == IP_CLIENT_DISCO)//sSBS.sPlayer.nIP_ConState < IP_CLIENT_PENDING && sSBS.sPlayer.nIP_ConState != IP_CLIENT_DISABLED)// { STACK_VAR SLONG nStatus; if(nLast_Local_Port == (SBS_LOCAL_IPPORT_1STBASE + sSBS.sPlayer.nDev_Instance)) { nLast_Local_Port = (SBS_LOCAL_IPPORT_2NDBASE + sSBS.sPlayer.nDev_Instance); } else { nLast_Local_Port = (SBS_LOCAL_IPPORT_1STBASE + sSBS.sPlayer.nDev_Instance); } fnDevMod_DeBug("'SBS MOD-[ ',itoa(sSBS.sPlayer.nDev_Instance),' ], host IP-[ ',sSBS.sPlayer.cIP,' ], Attempting IP_Open :DEBUG<',ITOA(__LINE__),'>'"); sSBS.sPlayer.nIP_ConAttempts++; sSBS.sPlayer.nIP_ConState = IP_CLIENT_PENDING; WAIT 150'WAITING_TO_CONNECT' { sSBS.sPlayer.nIP_ConState = IP_CLIENT_DISCO; } nStatus = ip_bound_client_open(dvSBS.Port,nLast_Local_Port,sSBS.sPlayer.cIP,sSBS.sPlayer.nPort,1);1STBASE was 57600 and 2ndBASE was 57700 but alas it did not work and I really thought it might. I still get: at least with my issue if I try to close even though I'm already closed I get the error "port already closed' which makes me fairly confident that the master has actually closed all ties to the server but if that's the case what does rebooting the master do that allows me to re-connect once finished rebooting. That's what made me think it was re-using the local IP port (not to be confused with local port or dev port).That's what I was doing but I figured if I had 5 server, 5 module instances which most of the time aren't being used then why maintain the socket connection. Not that I'm worried about running out of my available IP connections. I was already turning off unsolicited feedback too so other than maintaining the socket I wasn't polling, parsing or dealing with the unsolicited stuff.
So I can easily go back to the way it was before I got this dumb idea but now there's the challenge of knowing "why" this is happening or should I say not happening.
Tried again using ip_bound_client_open with a fixed IP port and then again toggling between two fixed IP ports while terminating on the server side and it still won't re-connect until I reboot. So what is the reboot clearing or resetting?
With the advent of more and more IP devices, I'm seeing a lot more IP related errors, and I suspect it isn't just an AMX problem (though I think some AMX firmwares have issues as well). But then a shortcoming in the AMX socket handling trips over a shortcoming in the device socket handling, this kind of thing results: a difficult to find and illogical error situation that you can't seem to resolve. Some IP devices I have never had a problem with, ever. And others I have had so many issues I fell back to RS-232. But I'm afraid a lot of it is under the hood and out of our hands.
I'm gonna try to analyze this a bit with WireShark but that's not that easy to do on a switched network and what networks aren't switched. Most switches only pass broadcast and multicast packets to all ports and subsequently the PC running WireShark and most of want I need to look at is unicast traffic and the switches just pass those packets from point A to B. I do have a Cisco 2960 switch so I gonna attempt to set up a monitor (SPAN) port on it so that specific switch port traffic is mirrored and routed to my monitor port but I haven't been able to get that to work yet. I actually did have it working for a bit but I screwed it up trying to tweak it and I can't get it back.
Here's a link to the SPAN RSPAN setup for a Cisco 2960
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_37_se/configuration/guide/swspan.html
In my case it will resolve by just rebooting the master but it will also resolve if i just reboot the server (device) and that doesn't make any sense at all. I think I'll try rebooting the switch and see if that too will resolve the issue.
I'm using an NI-3100 running the latest and I've tried an NI700 running an older version and both were the same.
Something else you can do is watch the strings coming from the server back to the client on your NI. These don't show up in diagnostics but you can watch data.text to see exactly what the server is sending to the NI. All the communications will be strings as described in the telnet protocol -- you can send commands and respond to queries from the server.
All communications between the client and the server are these strings that are sent back and forth. There are no magic status connections or anything. The only way the server knows what the client status is is because of the strings sent by the client and/or responses (or lack of responses) by the client to server queries.
What all this amounts to is learning enough about the telnet protocol so that you can solve the problem and make up for the deficiencies in the AMX IP client. You can probably do that by studying the details of the telnet protocol (start with RFC 854) but that's brutal. Much easier to just sniff out how your PC client does it and copy the details.
