Dreambox 5000 IP module
ajish.raju
chief evangelist of favante
Thanks for module
I would suggest to use first_local_ip_port_avalaible (check syntax, it's from memory
instead of passing dev parameter, it would make it yet more simple ! -
First_local_port does not give you the 'next available' local port. It is essentially a constant 3 or 2 (I can't remember which) a bunch of modules with First_local_port are all going to and use the same IP port. I would not suggest hard coding a device in a module and forcing the rest of the world to just deal with it.
ericmedley wrote: »First_local_port does not give you the 'next available' local port. It is essentially a constant 3 or 2 (I can't remember which) a bunch of modules with First_local_port are all going to and use the same IP port. I would not suggest hard coding a device in a module and forcing the rest of the world to just deal with it.
+1. . -
my fault, made a confusion
