Denon BluRay protocol
Has anyone used a Denon 2012UDCI BluRay player? I am having trouble directly selecting a Track or Title using RS232.
I can play, stop, pause and other functions but direct track select does not work.
I downloaded a file posted by Tonyangelo but it does not include direct track selection.
Any ideas?
Thanks.
  • a_riot42a_riot42 AMX Wizard
    Kenny wrote: »
    Any ideas?
    Thanks.
    You might want to post the code you are using to do a direct select. From what I recall you have to insert the selection into the command using the ascii value.
    Paul
  • viningvining X Member
    Kenny wrote: »
    Any ideas?
    Title: 02,4C,31,x1,x2,x3,x4,03
    Track: 02,4C,32,x1,x2,x3,x4,03
    0-9999
    Where x1 = 1000 digit
    Where x2 = 100 digit
    Where x3 = 10 digit
    Where x4 = 1 digit
  • ajish.rajuajish.raju chief evangelist of favante
    I have searched the protocol pdf for these ir functions.
    source
    mode
    disc layer
    Any idea on these commands?
  • KennyKenny Junior Member
    A_riot got it right.
    I was using $03 as the track number to get to track 3. Changed it to $33 and all is well.
    Thanks.
