Dynamic Images via FTP - multi-line welcome message bug
in AMX Hardware
So I couldn't figure out why trying to load images from a FileZilla server worked in TPD4 but whenever I sent it to the panel I got nothing. Looking at the FZ server output and seeing the panel try to login but never got past sending USER. Hours of searching in vain here for 'dynamic image' (if only the forums supported TLA's in search this would have been much easier) I saw posts from most people grabbing their dynamic images of the NI's FTP server so thought maybe that's the only way to do it.
THEN
while upgrading an X series panel I saw the following note in changes:
-- Fixed problem downloading dynamic images via FTP if the server has multiple lines of welcome text
*Screams a few of my own TLA's*
Is this known issue documented anywhere? How was I supposed to know this?
THEN
Calling Tech Support will often get you info of issues in progress, but they don't seem to share much of that internally either. Or they might be told not to "know". I know I've reported some issues 5 times only to be told 5 times that each was the first such report.
But consider that anytime you call Tech Support, the first question will be "are you on the latest firmware?" so you might start there on every issue before calling...
All other touchpanels I've tested on (TPI-PRO, 8400) with the latest firmware still has this bug.
