RPM - RAPID PROJECT MANAGER
Hi friends,
The new AMX RPM desapoint me whyyy????
-i cant add new devices
-only a predefinied systems and deploys
-when you finish, the generate a propietary code and only you can send it into the NI with the rpm loader...
If you use it, please how can add a another switcher like Atlona????
Prove it
Atomico64
  • travis
    travis Junior Member
    Anyone deployed a project yet?
  • HARMAN_Chris
    HARMAN_Chris Harman Professional University
    atomico64,
    RPM is a highly configurable cloud based tool. Can you elaborate on what you mean by pre-configured rooms only? When a new project is created, there are multiple room types that can be selected -- as well as a "custom" room type. In all of the room types, you can add-to or remove-from those designs. There are arrows next to each device type that allow you to change the quantities. To remove something from a room design, take the quantity to zero.
    When we released this free tool to the community, we did stipulate that all RPM solutions will need to use AMX/AutoPatch video switching. You can go direct to a display as a third option. This was a choice we made - if you want to use our tool for free code, you will use our video switching products. If you need to use a different manufacturer for video switching, feel free to write custom code.
    Chris
  • Joe
    Joe Junior Member
    I realize this is an old post, but I have found myself needing to use RPM because of a user-specified MPC-108. And this system does have an Atlona switcher in it. So how does one go about adding control for this to the MPC-108?
    I would much rather knock something out in Studio, but apparently that isn't an option with these control pads.
    Joe
