problems receiving messages (some get lost)
Hello again!
i´m facing some problems with a Radvision´s XT1000 videoconference connection.
First, i stablish the connection like with many other devices, using an ip_client connection
And it sometimes takes minutes, trying once and again...
ip_client_open(dvVidConf.PORT,acIpVidConf,nVidConfPort,IP_TCP)
Note: "nVidConfPort" is 55003.
And second, once the connection is made, some broadcast messages sent by the videoconference (status messages mainly) are lost by the master, and i´m sure that the messages are sent by the videoconference because i can read them in a telnet software at my PC, but the Master doesn´t.
Any idea why is it happening?
Is there a way to "force" the Master to read its "dev" input buffer faster or something?
Thanks in advance!
  • viningvining X Member
    Need to show the code. The string_event handler and function call if the handler calls one for processing/parsing the rx data. Next it would be nice to see your connection handling code, where it's called and re-called, etc. online, offline, onerror stuff. Otherwise there's not much advice anyone could give.
