TASCAM CD-RW901 SL PROTOCOL PROBLEM
neoplus7
TASCAM PROTOCOL DOWNLOAD HERE
hi
i want some problem to TASCAM CD-RW 901 SL.
source code is it.
but it is do not controll.
where is the problem ??
appending the protocol
hi
DEFINE_DEVICE
dvCDRec = 5001:1:1 //TASCAM_CD-RW901 SL
dvTP = 10001:1:1
DEFINE_CONSTANT
volatile integer CDREC_CONTROL_BTNS[]=
91, 92, 93, 94, 95, 96, 97, 98, 99, 100,
101
DEFINE_EVENT
DATA_EVENT[dvCDRec]
online:
send_command data.device,"'SET BAUD 38400,N,8,1 485 DISABLE'"
send_command data.device,"'HSOFF'"
BUTTON_EVENT[dvTP,CDREC_CONTROL_BTNS]
push:
switch( get_last( CDREC_CONTROL_BTNS ) )
case 1: send_string dvCDRec,"$0A,'012',$0D" //PLAY
case 2: send_string dvCDRec,"$0A,'01401',$0D" //PAUSE
case 3: send_string dvCDRec,"$0A,'010',$0D" //STOP
case 4: send_string dvCDRec,"$0A,'01601',$0D" //REW
case 5: send_string dvCDRec,"$0A,'01600',$0D" //FF
case 6: send_string dvCDRec,"$0A,'01A01',$0D" //SKIP REW
case 7: send_string dvCDRec,"$0A,'01A00',$0D" //SKIP FF
case 8: send_string dvCDRec,"$0A,'01301',$0D" //REC
case 9: send_string dvCDRec,"$0A,'03700',$0D" //REPEAT OFF
case 10: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT SINGLE
case 11: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT ALL
source code is it.
SEND_COMMAND dvCDr, 'SET BAUD 19200,N,8,1' cPlay = "$0A,$30,$31,$32,$0D"; cStop = "$0A,$30,$31,$30,$0D"; cReverse = "$0A,$30,$31,$36,$30,$31,$0D"; cForward = "$0A,$30,$31,$36,$30,$30,$0D"; cPrev = "$0A,$30,$31,$41,$30,$31,$0D"; cNext = "$0A,$30,$31,$41,$30,$30,$0D"; cRecord = "$0A,$30,$31,$33,$30,$31,$0D"; cAssignTrack = "$0A,$30,$31,$33,$30,$32,$0D"; cMonitor = "$0A,$30,$31,$33,$30,$33,$0D";
ah....
set baud rate is wrong?
thank you
try this setting use. -
Baudrate was wrong, yes
Yeap
If baud rate is OK,
try as follows:
push:
switch( BUTTON.INPUT.CHANNEL)
case 91: send_string dvCDRec,"$0A,'012',$0D" //PLAY
case 92: send_string dvCDRec,"$0A,'01401',$0D" //PAUSE
case 93: send_string dvCDRec,"$0A,'010',$0D" //STOP
case 94: send_string dvCDRec,"$0A,'01601',$0D" //REW
case 95: send_string dvCDRec,"$0A,'01600',$0D" //FF
case 96: send_string dvCDRec,"$0A,'01A01',$0D" //SKIP REW
case 97: send_string dvCDRec,"$0A,'01A00',$0D" //SKIP FF
case 98: send_string dvCDRec,"$0A,'01301',$0D" //REC
case 99: send_string dvCDRec,"$0A,'03700',$0D" //REPEAT OFF
case 100: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT SINGLE
case 101: send_string dvCDRec,"$0A,'03701',$0D" //REPEAT ALL
Just have a try.
If the problem is sovled,reply `.` -
thak you for help me
