Variables as Variables
I have several sets of arrays with similar data, Array1, Array2, Array3 and I have a set of identical functions that is triggered by the nSelectedInput Switch. Right now I've had to create 3 cases, one pointing to each different array. Is there a way to condense this so that the Array Selection is a Variable? The selected array will be pulling from other district arrays, so they cannot be combined into one very large array.
would like to do something simpler like:
SWITCH (nSelectedInput)
CASE 1 :
//Do Something with "Array1" (very long)
CASE 2 :
//Do Something with "Array2" (Identical to case 1, except for array name)
CASE 3 :
//Do Something with "Array3" (Identical to case 1/2, except for array name)
CASE 1 :
SelectedArray = Array 1 //Array1 Selected
CASE 2 :
SelectedArray = Array 2 //Array2 Selected
CASE 3 :
SelectedArray = Array 3 //Array3 Selected
//Now do something with the SelectedArray[x][x][x] (very long)
Now just reference the desired array with your SelectedArray value.
Edit: Or are you saying that you can't use a multidimension array in this case? If so then use a function that takes an array as a parameter.
Define_Structure _sMyStruct{ Integer MyArray[10] } define_variable _sMyStruct MyStruct[3] // and then in the switch case Switch(nSelectInput){ Case 1: Case 2: Case 3:{ myStructure[nSelectInput].MyArray[1]=something based on whatever into the first cell of MyArray. } }As you can see you can probably even ditch the switch/case since the channel ID will do the selecting for you.
A multimensional array essentially does the same thing. A structure is nice for organizing lots of different types of data in the same block. Things like mixtures of integers, chars, etc...
