Beyerdynamic Discussion System, String parsing
Can anyone help to decode the string sent by the Beyerdynamic discussion system[MCS D-200].
51 delegate units are attached to the main unit including chairman's mic; (first COM port is iCNS[PC] and second COM port is AMX control system).
I can start and stop each delegate unit using the hex commands in this format - $06,$0A,$01,$00,$01,$00,$01
But I couldn't show on the touchpanel that which mic is being pressed. It has become too difficult to decode the string. The stings sent by the MCS D200 has a random nature(please see attached). It will be really really helpful if anyone can tell something.
  • Do you have the device's control protocol? If so post it, if not find it.
  • arnmohanarnmohan Junior Member
    Attached. the protocol
    arnmohan wrote: »
    The strings that are listed in the protocol you attached are not random in nature. Here is what the format looks like to me:
    1) All strings are 7 bytes long.
    2) Bytes 1 and 2 are always $06 and $0A.
    3) Byte 3 is the mic address.
    4) Byte 4 is always $00.
    5) Byte 5 is the On/Off state ($01=On, $02=Off)
    6) Bytes 6 and 7 are always $00 and $01.
    HTH
    Joe Hebert wrote: »
    HTH
    Thanks for the reply
    The .txt file I've attached is describing protocol to activate/deactivate mic stations.
    Wht I'm asking is abt the reply from beyerdynamic main unit when a mic was turned on(manually or via RS 232). That string is not in a common format, then how can I determine which exact mic has been just turned on?
  • Where's the rest of the protocol? I checked their site but didn't see this model.
    vining wrote: »
    First byte always $06
    second byte always $0A
    3rd and 4th bytes are the LOGID of the mic.
    To figure byte 3 take the LOGID of the mic and Binary AND with $FF
    To figure the 4th byte take the LOGID of the mic and / $100
    The 5th byte is the on/off byte. 1 is on 2 is off.
    The 6th byte is to check 1 for request to speak queue or 0 for don't check
    the queue.
    Byte 7 is the group ID.
    And I used the parameters in the attached document, none of others describes its even parity.
  • Looks like the strings returned in the OP screen shot are in your supplied protocol setion:
    7.2 Speakerlist (Delegate stations on/off/requ)
    The speakerlist is sent to the Ext. Controller when a microphone is turned on or off.
    Where: 8,B,1,1,38,0,0,1,1 (9 bytes)
    byte 1 = LEN "8" (plus byte 1 for a total of 9 bytes)
    byte 2 = CMD "B"
    byte 3 = Sesson ID "1"
    byte 4 = Flag "1"
    byte 5 = Lo logID "38"
    byte 6 = Hi logID "0"
    byte 7 = Pos "0"
    byte 8 = State "1"
    byte 9 = Group ID "1"
    If you don't care about this stuff ignore it and just key on finding your first 2 fixed bytes:
    "Bytes 1 and 2 are always $06 and $0A"
    and then if the point where you find these string and the total length of the string is at least 7 bytes longer than the find point then dump up to the find point -1 and then grab the 7 byte string and parse.
    vining wrote: »
    Many thanks Vining,
    Bt I couldn't make out this part.(which you quoted above)
    I created a buffer of size 9 and analyzed a series of strings when more than 2 mics are activated, bt then the string was not in this format. I hope first 9 bytes will get replaced when the next reply comes, or else I'm missing the point where the buffer has to be cleared.
