RMS Enterprise configuration error database name.
When setting up RMS using the RMS Server configuration tool I'm getting the following error in the input field SQL Server Catalog(Database Name): the input field turns red and when I hover my mouse over the field it says "The database catalog is incompatible and cannot be used. Please choose a different catalog"
How do I create a compatible database catalog?
If you just enter the desired name of the catalog without creating it first it complains that the catalog doesn't exist, If I use SQL Server Management Studio and create a new database then I get the above error.
Windows Server 2008 Web edition
Java 6.0.37
Tomcat 6.0.36
SQL Express 10.0.1600.22
AMX RMS Server 4.0.52
RMS_Server.log
2012-11-06 08:03:16,389 ERROR [main] util.JDBCExceptionReporter [ ]- Invalid object name 'Version'.
2012-11-06 08:03:16,395 ERROR [main] spring.RmsLocalSessionFactoryBean [ ]- Caught hibernate exception.
org.hibernate.exception.SQLGrammarException: could not execute query
	at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:92)
	at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:66)
	at org.hibernate.loader.Loader.doList(Loader.java:2536)
	at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java:2276)
	at org.hibernate.loader.Loader.list(Loader.java:2271)
	at org.hibernate.loader.criteria.CriteriaLoader.list(CriteriaLoader.java:119)
	at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1716)
	at org.hibernate.impl.CriteriaImpl.list(CriteriaImpl.java:347)
	at com.amx.rms.spring.RmsLocalSessionFactoryBean.verifyDatabaseVersion(RmsLocalSessionFactoryBean.java:100)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1546)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1487)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1419)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:518)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:455)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:293)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:290)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:192)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1327)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1085)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:516)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
	at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:282)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:204)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
	at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
	at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: java.sql.SQLException: Invalid object name 'Version'.
	at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
	at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
	at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
	at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
	at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:477)
	at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:778)
	at com.mchange.v2.c3p0.impl.NewProxyPreparedStatement.executeQuery(NewProxyPreparedStatement.java:76)
	at org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatcher.java:208)
	at org.hibernate.loader.Loader.getResultSet(Loader.java:1953)
	at org.hibernate.loader.Loader.doQuery(Loader.java:802)
	at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
	at org.hibernate.loader.Loader.doList(Loader.java:2533)
	... 69 more
2012-11-06 08:03:16,463 ERROR [main] context.ContextLoader [ ]- Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsEntityInterceptor' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsMetadataValueDao' while setting bean property 'metadataValueDao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsMetadataValueDao' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsMetadataValueDao' defined in class path resource [applicationContext-hibernate.xml]: Cannot resolve reference to bean 'rmsSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	... 39 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rmsSessionFactory' defined in class path resource [applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1422)
	... 49 more
Caused by: org.hibernate.exception.SQLGrammarException: could not execute query
	... 56 more
	... 69 more
2012-11-06 08:06:10,897 ERROR [main] util.JDBCExceptionReporter [ ]- Invalid object name 'Version'.
2012-11-06 08:06:10,926 ERROR [main] spring.RmsLocalSessionFactoryBean [ ]- Caught hibernate exception.
	... 69 more
2012-11-06 08:06:11,014 ERROR [main] context.ContextLoader [ ]- Context initialization failed
	... 39 more
	... 49 more
	... 56 more
	... 69 more
RMS_Server_Configuration_Tool.log
2012-11-05 15:29:40,790 INFO  [Thread-4] configuration.ProgressMonitorImpl - 0/100 : Mon Nov 05 15:29:40 CAT 2012 - Preparing database catalog install...
2012-11-05 15:29:40,813 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Done!
2012-11-05 15:29:40,819 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Mon Nov 05 15:29:40 CAT 2012 - Catalog already exists, skipping creation.
2012-11-05 15:29:40,820 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 :
2012-11-05 15:55:45,767 INFO  [Thread-4] configuration.ProgressMonitorImpl - 0/100 : Mon Nov 05 15:55:45 CAT 2012 - Preparing database catalog install...
2012-11-05 15:55:45,781 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Done!
2012-11-05 15:55:45,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 5/100 : Mon Nov 05 15:55:45 CAT 2012 - Catalog already exists, skipping creation.
2012-11-05 15:55:45,790 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 :
2012-11-05 15:55:46,093 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Mon Nov 05 15:55:46 CAT 2012 - Creating catalog tables...
2012-11-05 15:55:50,466 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Done!
2012-11-05 15:55:50,467 INFO  [Thread-4] configuration.ProgressMonitorImpl - 10/100 : Mon Nov 05 15:55:50 CAT 2012 - Creating scheduler tables...
2012-11-05 15:55:50,746 INFO  [Thread-4] configuration.ProgressMonitorImpl - 15/100 : Done!
2012-11-05 15:55:50,747 INFO  [Thread-4] configuration.ProgressMonitorImpl - 15/100 : Mon Nov 05 15:55:50 CAT 2012 - Creating system data...
2012-11-05 15:55:51,914 INFO  [Thread-4] configuration.ProgressMonitorImpl - 20/100 : Done!
2012-11-05 15:55:51,916 INFO  [Thread-4] configuration.ProgressMonitorImpl - 20/100 : Mon Nov 05 15:55:51 CAT 2012 - Creating default data...
2012-11-05 15:55:52,018 INFO  [Thread-4] configuration.ProgressMonitorImpl - 25/100 : Done!
2012-11-05 15:55:52,019 INFO  [Thread-4] configuration.ProgressMonitorImpl - 25/100 : Mon Nov 05 15:55:52 CAT 2012 - Creating asset type images...
2012-11-05 15:55:52,506 INFO  [Thread-4] configuration.ProgressMonitorImpl - 30/100 : Done!
2012-11-05 15:55:52,506 INFO  [Thread-4] configuration.ProgressMonitorImpl - 30/100 : Mon Nov 05 15:55:52 CAT 2012 - Creating model data...
2012-11-05 15:55:53,695 INFO  [Thread-4] configuration.ProgressMonitorImpl - 35/100 : Done!
2012-11-05 15:55:53,695 INFO  [Thread-4] configuration.ProgressMonitorImpl - 35/100 : Mon Nov 05 15:55:53 CAT 2012 - Updating Admin account...
2012-11-05 15:55:58,759 INFO  [Thread-4] configuration.ProgressMonitorImpl - 86/100 : Done!
2012-11-05 15:55:58,760 INFO  [Thread-4] configuration.ProgressMonitorImpl - 86/100 : Mon Nov 05 15:55:58 CAT 2012 - Updating user accounts...
2012-11-05 15:56:00,156 INFO  [Thread-4] configuration.ProgressMonitorImpl - 87/100 : Done!
2012-11-05 15:56:00,157 INFO  [Thread-4] configuration.ProgressMonitorImpl - 87/100 : Mon Nov 05 15:56:00 CAT 2012 - Creating access control lists...
2012-11-05 15:56:00,339 ERROR [Thread-4] core.SpringSecurityCoreVersion - Spring Major version '3' expected, but you are running with version: . Please check your classpath for unwanted jar files.
2012-11-05 15:56:12,993 INFO  [Thread-4] configuration.ProgressMonitorImpl - 90/100 : Done!
2012-11-05 15:56:12,993 INFO  [Thread-4] configuration.ProgressMonitorImpl - 90/100 : Mon Nov 05 15:56:12 CAT 2012 - Indexing database...
2012-11-05 15:56:13,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 95/100 : Done!
2012-11-05 15:56:13,789 INFO  [Thread-4] configuration.ProgressMonitorImpl - 95/100 : Mon Nov 05 15:56:13 CAT 2012 - Optimizing database...
2012-11-05 15:56:14,553 INFO  [Thread-4] configuration.ProgressMonitorImpl - 100/100 : Done!
Any pointers?
