Any way to dual network a master?
jabramson
in AMX Hardware
I have 2 networks and I'd like my master to be on both (and have an IP on both). Is there a way to add a second Ethernet port?
The simple answer is no. The NIC card in it is obviously something off the shelf and I'm sure there might be a way to brick it and use another instance on the card. I don't know if the firmware is able to deal with a second interface instance on the same NIC.
However, what's stopping you from making the connection from the switch or router? Just make a firewall rule or a route through the switch(es) -
Can't really provide any targeted suggestions on how to proceed as we don't know the scenario you need two NIC's for, but one option would be to use an Ethernet - serial adaptor plugged into a serial port on the control system to get you the second NIC. May or may not do what you need depending on what you are trying to achieve...
