AMX MET-6N KeyPad
amarchis
Hello,
I'm trying to flash a button on my KeyPad during a power on of a Projector: I already tried with while, set_pulse_time and pulse but my button doesn't flash.
Which is the trick?
Many thanks
Andrea
Which is the trick?
Many thanks
Andrea
I generally have a timeline that is running on a .5 or 1 second cycle. If I need a flashing button, there would be a series of lines in the timeline that will flash and unflash the button.
In the define_variable area i have a line like this:
VOLATILE INTEGER FLASH = 1
In the timeline would be the following code:
FLASH = !FLASH
IF ([vdvDVR1,244])
[dvKeypad,1]=FLASH
In the above example, if channel 244 is on in the DVR virtual device it is in record mode andI flash the record button.
For something like a projector warm-up, you would probably want to flash the button during the warmup/cooldown process and then force the button on or off depending on the state of the projector. -
From experience, these commands only set the brightness values for the on/off states. They still need to be cycled on/off. The above command only needs to be sent one time in the online event of each keypad. -
True, but it may be related to TS' problem
If the "On" brightness was set to 0% then the button doesn't flash
