Touch panel connected to the SSID if they change the NetLinx command??
hi
For example, I was wondering if command is like the title, I have installed the AP with multiple SSID SSID that is connected to the touch panel, you can change one of the MVP-8400 Touch Panel.
Sent from my iPhone using Tapatalk
I suppose you could write a program to telnet into he panel itself and change some things. Bit you'd lose connection at some point. So you'd need to make sure you did what you need to before sending he reboot command.
I do a similar thing to send errant touch panels that accidentally connect to the wrong meter at a multi-master installation.
