Install pages from external disk
Apparently, the new X series panels do not support a Virtual Netlinx Master for previewing panel layouts. Or so says AMX support. However, in settings, under Confi > Admin, there is a "Install Pages from External Disk" button. The Programming guide says "Select this to install touch panel pages from an external disk, such as a USB stick. If an external disk is not connected to the touch panel, this field will be greyed out."
I have attempted the obvious, loaded the TPD4 file on a USB and inserted in slot. The button is still greyed out.
Has anybody successfully used this feature?
  • jtalley
    jtalley AMX Engineering
    Place the TPD files in a folder off the root of the flash disk with the name of the panel just like you were upgrading firmware with a kit file.
    For instance, if you are using a MXT-2000XL-PAN, name the folder MXT-2000XL-PAN (the same name that shows up in Setup->Status->Panel Type), and place your TPD files in that folder.
    Then go to Setup->Configuration->Admin->Install From External Disk and you should see all your TPD files in that folder.
  • CopperTop
    CopperTop Junior Member
    Great. Worked perfectly. Thanks!
    Much easier then using the virtual master.
