MVP-9000i get batt telnet command
dspot
dspot Junior Member
Here is something I just noticed. I connected to an MVP-9000i via telnet and sent the get batt command. The result is (i hope) wrong.
Presence : Not present
Charge Status : Charged
Fault Status : No fault
Is Battery Smart: No
The same MVP shows Charged on the power management - charge status. I hope this is just a firmware problem. Firmware is v2.86.31.
  • vining
    vining X Member
    This is what I get:
    MVP 1
    Welcome to MVP-9000i v2.86.31 Copyright (C) AMX LLC 2002-2010
    >get batt
    Presence : Present
    Fault Status : No Fault
    Charge : 99 %
    Voltage : 8400 mV
    Current : +0 mA
    Temperature : 33 C
    Is Battery Smart : No
    MVP 2
    >get batt
    Presence : Present
    Charge : 100 %
    Voltage : 8378 mV
    Current : +0 mA
    Temperature : 35 C
  • dspot
    dspot Junior Member
    nothing done besides some charge-discharge cycles, and when I rechecked, it looks the same like yours. weird.
  • DHawthorne
    DHawthorne Junior Member
    It probably polls the battery in specific intervals, and you caught it between polls. The old Viewpoints used to do that too ... when you first called up the battery page after going on or off power, it took a minute or so for the gauge to be accurate.
