MVP8400 Security Settings
Hi,
Im having a little trouble using the security feature for a Modero 8400. Im trying to use WEP128 and have followed the instructions supplied with the AMX WAP200G but i cant get the panel to send any commands i.e button pushes do not send the required information to the master. The panel is online as it can recieve commands and level events fine. Anyone experienced anything like this before? Any help would be appreciated.
Cheers,
Shane
Cheers,
Shane
One other thing you may want to try is to Enable the Push Message Status Bar Display from the Diagnostics menu in Netlinx Studio and see what shows up there when you press a button on the MVP. I?m with Dave; the security settings should be fine if the MVP is ONLINE and receiving commands.
Anyway thanks guys.
Shane
I have also on odd occasions have had a panel that connected to the network but still could not communicate properly, and it turned out to be a signal quality issue. Moving the access point fixed it.
This is one of those cases where the terminology needs some clarification. There are several connections that need to be made before a panel will work, and it's important to recognize which is not working, especially when talking to someone else about it.
