AXLink/ICSP error
in AMX Hardware
Hi,
I have a system consisting of a NXC-ME260 (3.60.453) with 3 COM2 cards, 1 IRS4 card and one relay card, plus two remoted relay cards via ICSnet (each in its own enclosure with looping ICSnet)
Suddenly, after running fine for years, the system starts spewing several hundred the following messages to the console, and then reboots. After rebooting, before the user program starts to execute, the same messages start getting issued and the system reboots every minute or two.
(1131722465) CAxlinkRX::ParseICSPMessage First byte not fixed byte (D1)
(1131722466) CAxlinkRX::ParseICSPMessage First byte not fixed byte (D1)
(1131722467) CAxlinkRX::ParseICSPMessage First byte not fixed byte (D1)
(1131723516) CAxlinkRX::ParseICSPMessage First byte not fixed byte (0)
(1131723517) CAxlinkRX::ParseICSPMessage First byte not fixed byte (0)
(1131723518) CAxlinkRX::ParseICSPMessage First byte not fixed byte (F5)
Then just as suddenly, the system becomes stable and continues working. This has happened only twice (three weeks apart) and both times the system has recovered before I could get to the site to observe and or test. No luck at trying to replicate it manually.
Has anybody seen this before?
David
David
Keep in mind it could be a bad wire too. Axlink is horrible to troubleshoot because of the wiring topology (everything parallel); thankfully, it's very robust and these kind of issues are relatively rare.
Just sayin...
E
Thanks for the replies. I may just shotgun it and replace all of the cards. I wish that it would fail when I'm actually on-site (or just stay failed instead of fixing itself).
Fortunately the wiring topology is simple: three com2, one rel8, one irs4 n the main frame, plus two REL8 extended via ICSnet. I wonder if errors ICSnet extended cards would show up with this same AXlink message, or would it be wrapped with different message.
David
I don't think so. ICSNet is a different animal.
