device mappings missing
I've just opened a workspace I worked on a month ago and tried to add a new irl file.
I noticed then that all my devices are showing [Invalid Device]
If I attempt to map the irl, the Device Mapping dialog no longer contains any of my devices in the RH pane - just Custom. All the devices in the LH pane have a red cross beside them.
Anyone know what has happened here and how I can get the mapping back?
slip
slip
I put my devices in a separate file called Devices.axi and they do not appear in the mappings Dialog.
I think they must be in the Main Source File to show up in the Device Mappings Dialog.
Has anyone else seen this?
As a test, can you enable the EDIT toolbar and click on the RESCAN CURRENT SOURCE FILE icon (an axs with a circular arrow)? Once complete, check your mappings.
Chris
I'm stumped as to why they have disappeared.
Last time I work on this project they were there.
Regards
slip
Outstanding, that was it.
Thanks very much. I must admit I don't remember changing the text but it was all lower case.
Kudos to you.
Regards
slip
I take this bit you in the a ss once upon a time but how the heck did you come about making the connection between caps & maps? I don't recall ever seeing any posts about this. I always use caps for esthetic reasons and i generally don't use or care about device mapping but if i did and i had this problem it would never have dawned on me that it cuz of this. Another funky bug i suppose.
slip
Also, if you do something like the following: ...you'll run into mapping problems (for the obvious reasons.)
