Hex Value Madness
sling100
sling100 Junior Member
Guys
I've got myself stuck with a hex string return from a piece of broadcast kit.
It sends back the elapsed time in HEX, but the values it sends actually represent DECIMAL values
For example.....
Line 330 (12:32:58):: String From [5001:7:1]-[$74$00$49$46$01$00$04]
The actual time is 00h(char 6),01m(char 5),46s(char 4). Note the 46 - not 70 (ie decimal $46)
The only way I can think of presenting each char as 2 digit ascii text for my panels is ...
FORMAT('%02d',ATOI(ITOHEX(cData[4]))) - which seems a bit convoluted to say the least!
I'm sure I'm missing something here, but I haven't seen any daylight for 48 hours and I think it's affecting me a bit!
Simon
  • jweather
    jweather Junior Member
    Looks right to me... assuming it works, what's the problem? Just make sure you comment it with the expected input format so the next guy (possibly yourself 6 months later) doesn't say "that can't possibly work, I'll fix it"
  • Andrew G Welker
    Andrew G Welker Junior Member
    sling100 wrote: »
    Guys
    For example.....
    Simon
    This looks to be Binary Coded Decimal, which is actually pretty easy to deal with. See this thread for more information. Basically, you can take the character $46, which has the equivalent integer value of 70 (16 * 4 + 6) and do a modulo operation with 16 to get the ones place, then you can divide the same number by 16 and multiply by 10 to get the ones place.
    Define_function integer fnDecodeBCD(char bcd){
         return (bcd/16 * 10) + (bcd % 16)
    define_function char fnEncodeBCD(int bcd){
         return (bcd/10 * 16) + (bcd % 10)
    Hope that helps.
  • dchristo
    dchristo Junior Member
    sling100 wrote: »
    Guys
    For example.....
    Simon
    How about this?
    FORMAT('%02X', cData[4])
    --D
  • sling100
    Thanks chaps.
    My method does work, it just looks a mess - Andrew's BCD function would make it look a lot cleaner for sure.
    Dchristo - not sure that would work? Won't that return a hex value? Or maybe that's what I want .... Hmm.
    I'm off to have another try!
    S
