Russound CAS44 control
thepainter
As a Newbie DIY type I may have bitten off more than I can chew but have had very helpful responses in the past through the forum. I'm trying to control a Russound CAS44 Multi zone controller through a DIGI Port server (192.168.1.132:2102) I have a working code, controlled using iRule (Zone 2 Power On)
\xF0\x00\x00\x7F\x00\x00\x71\x05\x02\x02\x00\x00\xF1\x23\x00\x01\x00\x01\x00\x01\x14\xF7
I've tried with and without carriage return and am not sure what I'm doing wrong.
BUTTON_EVENT [TP_LOFT, 76] //LOFT POWER ON RUSSOUND ZONE 2
PUSH:
SEND_STRING DIGI, "'$F0,$00,$00,$7F,$00,$00,$71,$05,$02,$02,$00,$00,$F1,$23,$00,$01,$00,$01,$00,$01,$14,$F7', $OD"
PUSH:
SEND_STRING DIGI,'$F0,$00,$00,$7F,$00,$00,$71,$05,$02,$02,$00,$00,$F1,$23,$00,$01,$00,$01,$00,$01,$14,$F7'
Paul
PUSH:
PUSH:
Paul
You need to do an IP_CLIENT_OPEN first for the IP/Port used to connect to the digi. The digi can be a maintained connected but you need to track its state in case it falls offline and then re-con.
Then you need to config the digi for your conected device. Let us know where in this process you are, show more code and we'll try to lend a hand. -
I duplicated what I had set up for my Global Cache which worked from the get go.
DEFINE_DEVICE
DIGI = 0:8:0
DEFINE_START
IP_CLIENT_OPEN(DIGI.PORT, '192.168.1.132', 2102, IP_TCP)
DEFINE_EVENT
DATA_EVENT[DIGI]
OFFLINE:
(* TRY ANOTHER CONNECTION *)
DEFINE_EVENT
PUSH:
SEND_STRING DIGI, '$F0,$00,$00,$7F,$00,$00,$71,$05,$02,$02,$00,$00,$F1,$23,$00,$01,$00,$01,$00,$01,$14,$F7'
UPDATE
Got some advice from someone at RC "Drop the single Quotes" and it worked like a charm with and without the carriage return.
Got rid of the single quotes and worked like a charm, with and without the carriage return.
PUSH:
SEND_STRING DIGI, "$F0,$00,$00,$7F,$00,$00,$71,$05,$02,$02,$00,$00,$F1,$23,$00,$01,$00,$01,$00,$01,$14,$F7, $0D"
Paul
