VST-C issue
Any one have issues with the O, cool reversing valve relay output on VST-C. Just received ten to install and had 3 from stock that had been updated back in TX to the new software a few months back. The old ones work correctly the new ones seem to be backwards on the O and B outputs.
More specifically: Mode is setup for dual stage, electric. The O reversing valve on the new VSTs does not energize when cool is called for. However, B does. My older but updated VSTs O is energized when cool is called for. I don't seem to be able to find any setup or software setting to swap this characteristic. Wiring to B makes them work, but I don't believe it should and will be a service issue for the HVAC company in the future I fear.
Thanks in advance for any assistance or opinions.
  • terrmul
    terrmul Junior Member
    Same thing
    Just had a new one replace an older one and this is the same on ours. Switched to B and it's fine. Fortunately my technical service contract has run out so I have to figure out AMX's issues for them.
