IR OK Command to STB
craig
Hello All,
We are still awaiting to have our touch panel replaced so I am back to telnetting into our AMX NI-3100. I can successfully telnet into the AMX controller and send the command to change the settop box(STB) channel via the IR.
SEND_COMMAND 5001:9:0,"'XCH 1225'"
The STB(uverse) remote has an OK button - This OK button is used to power the STB On and Off
How can I send the OK command to the STB. I've tried the SEND_COMMAND 5001:14:0,"OK'" but ofcourse it does not work
Any help would be greatly appreciated
thanks,
Craig
+++++++++ found in a uverse forum +++++++
the signal for "OK" is
0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 000A 0006 001D 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 001D 0006 000A 0006 0C5B
thanks,
Craig
send_string dvDirecTV,"$FA,$A5,$00,$01,$C3"
Gary thanks for the response, but I was not able to get the STB to accept the OK command using the command that was posted - I modified the string as it would relate to my setup, but - I didn't get the command to register with the STB - maybe I have the wrong info for the OK signal ....
send_string 5001:9:0,"$FA,$A5,$00,$01,$C3"
SEND_COMMAND 5001:9:0,"$FA,$A5,$00,$01,$C3"
send_string dv_Uverse_1,"$FA,$A5,$00,$01,$C3"
Actually the OK button is about the only thing that works on the touch panel ... is there a way to capture or retrieve this info from the touch panel
Thanks Again
Craig -
Thanks Again
Craig
If I understand you correctly, the code that is driven by the touch panel's "ok" button is actually working. If that is the case then just look through the code for that button event and see what's going on in that event.
Also 5001:9:X is most commonly used for IR not RS-232. Are you 100% sure that the STB is connected via RS-232? -
Considering the title and information in the post I assume the STB is connected via IR.Bigsquatch wrote: »Also 5001:9:X is most commonly used for IR not RS-232. Are you 100% sure that the STB is connected via RS-232?
Within the AMX world controlling IR devices involves an additional level of abstraction to serial or IP control. The IR commands (such as the one in your initial post) must first by built into an *.irl file using IREdit. Each command takes a slot in the file which corresponds to a channel number. This is then loaded onto the device controller and you interact with it by pulsing the channel that holds the command you want sent or using the device controller API to do the same thing, just a little neater (buffering etc). Check out AMX-PI for all of them - 'XCH' is one of these.
To help you out with your initial problem what you'll need to do is use the file transfer tool to download the irl file that loaded onto 5001:9:0. You'll then be able to open this in IR edit and see what slot the OK command is in and if its not there add it. From there all you'll need to do is activate it when you want it sent. I recommend looking at using the 'SP' (look it up in AMX-PI for more info) to do this.
Also, this is all covered in AMX programmer training. -
..... I recommend looking at using the 'SP' (look it up in AMX-PI for more info) to do this.
Thanks Kim ... that answered my question ... I was able to use the SP command to send the IR pulse to the set top box.
SEND_COMMAND 5001:9:0,"'SP',49" ... works like a charm
Thanks again for everyone's help,
Craig
