Cisco C40 and Duet Module
Hi all.
I working on integrating a Cisco C40 codec to an existing AMX system and I am having some difficulties with the duet module. I have had success previoulsy using Netlinx modules but this is the first time I am using a duet module. I downloaded the appropiate module for the codec from AMX.com. When the module is loaded to the master and rebooted, with out any action on my part, the master continusouly sends commands to the codec, such as camera position, preset etc., below is a sample. With the flood of commands constantly comming in the camera wont respond to the remote control. The C40 is running firmware version 4.2 and I believe the module is verifed for version 4.0. Has anyone experienced similar issues with this module or any other like it? Is there something I'm missing?
ine 3413 (13:36:43):: Command To [33001:1:70]-[CAMERA_PTZF-400,60,40,4577]
Line 3414 (13:36:43):: Command From [33001:1:70]-[CAMERA_PTZF-400,60,40,4577]
Line 3415 (13:36:43):: String From [32002:1:70]-[SetResult item="1" status="OK"/>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId="2]
Line 3416 (13:36:43):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Tilt:60 | resultId="206"$0D]
Line 3417 (13:36:43):: String To [32002:1:70]-[$0A]
Line 3418 (13:36:43):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Pan:400 Tilt:60 Zoom:40 F]
Line 3419 (13:36:43):: String To [32002:1:70]-[ocus:4577 | resultId="207"$0D$0A]
Line 3420 (13:36:43):: String From [32002:1:70]-[00">$0D$0A<CameraPositionSetResult item="1" status="OK"/>$0D$0A</XmlDoc>]
Line 3421 (13:36:43):: String From [32002:1:70]-[$0D$0A<XmlDoc resultId="">$0D$0A<Status>$0D$0A<Camera item="1">$0D$0A <Position]
Line 3422 (13:36:43):: String From [32002:1:70]-[ item="1">$0D$0A <Pan item="1">397</Pan>$0D$0A </Position>$0D$0A</Camera]
Line 3423 (13:36:44):: String From [32002:1:70]-[>$0D$0A</Status>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId="201">$0D$0A<CameraPositio]
Line 3424 (13:36:44):: Level Value To [33001:1:70] - Level 27 Value= 124.000000
Line 3425 (13:36:44):: Command To [33001:1:70]-[CAMERA_PTZF-397,60,40,4577]
Line 3426 (13:36:44):: Command From [33001:1:70]-[CAMERA_PTZF-397,60,40,4577]
Line 3427 (13:36:44):: String From [32002:1:70]-[nSetResult item="1" status="OK"/>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId="]
Line 3428 (13:36:44):: String From [32002:1:70]-[202">$0D$0A<CameraPositionSetResult item="1" status="OK"/>$0D$0A</XmlDoc]
Line 3429 (13:36:44):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Pan:397 | resultId="208"$0D]
Line 3430 (13:36:44):: String To [32002:1:70]-[$0A]
Line 3431 (13:36:44):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Pan:397 Tilt:60 Zoom:40 F]
Line 3432 (13:36:44):: String To [32002:1:70]-[ocus:4577 | resultId="209"$0D$0A]
Line 3433 (13:36:44):: String From [32002:1:70]-[>$0D$0A<XmlDoc resultId="">$0D$0A<Status>$0D$0A<Camera item="1">$0D$0A <Positio]
Line 3434 (13:36:44):: String From [32002:1:70]-[n item="1">$0D$0A <Tilt item="1">34</Tilt>$0D$0A </Position>$0D$0A</Came]
Line 3435 (13:36:44):: String From [32002:1:70]-[ra>$0D$0A</Status>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId="203">$0D$0A<CameraPosit]
Line 3436 (13:36:44):: Level Value To [33001:1:70] - Level 28 Value= 34.000000
Line 3437 (13:36:44):: Command To [33001:1:70]-[CAMERA_PTZF-397,34,40,4577]
Line 3438 (13:36:44):: Command From [33001:1:70]-[CAMERA_PTZF-397,34,40,4577]
Line 3439 (13:36:44):: String From [32002:1:70]-[ionSetResult item="1" status="OK"/>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId]
Line 3440 (13:36:44):: String From [32002:1:70]-[="204">$0D$0A<CameraPositionSetResult item="1" status="OK"/>$0D$0A</XmlD]
Line 3441 (13:36:44):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Tilt:34 | resultId="20a"$0D]
Line 3442 (13:36:44):: String To [32002:1:70]-[$0A]
Line 3443 (13:36:44):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Pan:397 Tilt:34 Zoom:40 F]
Line 3444 (13:36:44):: String To [32002:1:70]-[ocus:4577 | resultId="20b"$0D$0A]
Line 3445 (13:36:44):: String From [32002:1:70]-[oc>$0D$0A<XmlDoc resultId="">$0D$0A<Status>$0D$0A<Camera item="1">$0D$0A <Posit]
Line 3446 (13:36:44):: String From [32002:1:70]-[ion item="1">$0D$0A <Pan item="1">400</Pan>$0D$0A </Position>$0D$0A</Cam]
Line 3447 (13:36:44):: String From [32002:1:70]-[era>$0D$0A</Status>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultId="205">$0D$0A<CameraPosi]
Line 3448 (13:36:44):: Level Value To [33001:1:70] - Level 27 Value= 125.000000
Line 3449 (13:36:44):: Command To [33001:1:70]-[CAMERA_PTZF-400,34,40,4577]
Line 3450 (13:36:44):: Command From [33001:1:70]-[CAMERA_PTZF-400,34,40,4577]
Line 3451 (13:36:44):: String From [32002:1:70]-[tionSetResult item="1" status="OK"/>$0D$0A</XmlDoc>$0D$0A<XmlDoc resultI]
Line 3452 (13:36:44):: String To [32002:1:70]-[xCommand Camera PositionSet CameraId:1 Pan:400 | resultId="
  • Joe Hebert
    Joe Hebert Junior Member
    One problem I see is that you are using Netlinx virtual device numbers instead of Duet virtual device numbers.
    If you are using a Duet module then the virtual devices have to start at 41001 not 33001.
  • Wjrich
    Wjrich Junior Member
    Joe Hebert wrote: »
    That fixed it! Thanks you so much you saved me soooo much time and headache.
