MVP-9000i Wireless Problems
Hi,
Has anyone had a problem with an MVP-9000i Panel not connecting to a Wireless Network due to having a very noisy Wireless Environment?
I can use an iPad/iPhone and have no problems what so ever which leads me to assume the Wireless Chipset in the AMX Panels arent that great.
Any help would be appreciated!
Cheers,
Dan
Cheers,
Dan
-- Dynamic WEP should not be used.
-- Known issues with EAP_TTLS security
-- There are still some situations where the Panel will disassociate from the access point, and not
reconnect that are under investigation.
Its possible you're being affected by one of these, though I don't know if the last two existed in the version on the website (2.53.24) and just hadn't been discovered when they wrote the notes for that version, or if they were added between that version and the one I have (2.53.29)
-Ryan
I also have seen that the site survey list is empty after it drops the wifi connection and there are at least 20 networks that should be showing.
Using Wpa psk
Ssid has no characters but is all caps
N is disabled
Channel auto is off auto and set to 1
Wap has macs of panels setup so they are the only macs to connect to it.
Any thoughts would be helpful. Multiple panels in multiple rooms seeing the same issue.
we went last week to upgrade to .31 just as we had upgraded ever panel in the past and got a 404 error saying a file was missing etc... tried a few times...
tried mvp-9000i and MVP-9000i folder names on flash drive.
I was going to try again in a few with a different flash drive... but I have never seen this
