RMS custom Source
Milad
Hi Everyone,
I am programming RMS 3.3.33, and have an issue adding custom sources to the i!-Connectlinx. Below are the lines that I'm using:
SEND_COMMAND DATA.DEVICE,” 'ADD STD-1001-1002&1014&1017-1018&1023' ”
SEND_COMMAND DATA.DEVICE,” 'ADD ACTION-1,Select Custom Source,Student PCs' ”
On the RMS Server and under "Execute Control Function", I see all the standard functions but not my custom added source. Can anyone help?
You need to make sure you have created the folder it is being placed in first. To do this use the `ADD FOLDER-{folder name}, {parent}` command. If you want the folder to be based in the root then just leave off the parent part.
Awesome! Thanks for that, it's working now.
