Read an sync bargraph on several panels - and keep the state
Hi Guys
I am having an issue, with reading a bargraph - and keep all bargraph on all three panels on the same level.
Alle panels contains the same project file.
The communication is running - and I got the values distrbuted to alle panels - but after aprox 10min the level goes to 0....
This is what I done:
DEFINE_VARIABLE
DEV ALLTP[] = {TP1,TP2,TP3,TP4} //ALL PANELS NAMED ALLTP
INTEGER BARGRAPH1 // STORE BARGRAPH1
DEFINE_EVENT
LEVEL_EVENT[ALLTP,1] // READ THE LEVEL OF THE BARGRAPH
BARGRAPH1 = LEVEL.VALUE // STORE THE LEVEL OF THE BARGRAPH
SEND_LEVEL VAO,1,BARGRAPH1 // SEND VALUE TO VAO4 OUTPUT
WAIT 50
SEND_LEVEL TP1,1,BARGRAPH1 // UPDATE BARGRAPH ON PANEL1
WAIT 50
SEND_LEVEL TP2,1,BARGRAPH1 // UPDATE BARGRAPH ON PANEL2
WAIT 50
SEND_LEVEL TP3,1,BARGRAPH1 // UPDATE BARGRAPH ON PANEL3
  • ericmedley
    I would handle this by creating a for loop and only sending/updating the level feedback to panels actively on the page/popup with the fader in question.
    something like.
    for(nloop=length_array(AllTPs);nloop;nloop--)
      if(TP_Fader_Feedback_active[nloop])
        send_level AllTPs[nloop], the level
  • regallion
    regallion Junior Member
    Is your source panel going offline after 10 mins and causing the level to drop to 0?
    May be worth putting a qualifier in the update:
    if(BARGRAPH1)
    	WAIT 50
    	WAIT 50
    	WAIT 50
    Also, I wouldn't use one panel as a source for others. Presumably you're setting the levels based on some other variable (like volume) ? Use that as the source data for all your panels.
  • PhreaK
    PhreaK Senior Member
    Have a look in the NetLinx Keyword Help at 'Combining and Uncombining Levels'. It'll give you a rundown on how to bind multiple levels to a virtual level.
