Passing IP Address to a Netlinx Module
Does anyone have any example of how to pass an IP address to a Netlinx Module?
  • the8thst
    the8thst Junior Member
    DEFINE_VARIABLE
    char cMY_IP[] = '192.168.1.125'
    define_module 'MyModule' instance1 (cMY_IP)
    Is that what you are asking for?
  • tpeery
    tpeery Junior Member
    the8thst wrote: »
    DEFINE_VARIABLE
    I have defined my ip address in my define module like this.
    (dev vdvprojector, dev dvprojector,dev dvtp, char lamp_hour_text_field, CHAR projector_ip)
    Then in my main program I have defined like this
    comm(vDVMON1,DVPROJECTOR1,dvtp,14,projector_1_ip)
    What I get in the complier is that the char of projector_1_ip is that it is an expression.
    Any ideas?
  • the8thst
    Both amp_hour_text_field and projector_ip are being declared as single byte character variables. You want to make them into an array of appropriate length.
    Change
    to
    (dev vdvprojector, dev dvprojector,dev dvtp, char lamp_hour_text_field[4], CHAR projector_ip[15])
    I just guessed on the lamp hour length.
  • tpeery
    the8thst wrote: »
    Change
    to
    Thanks I got it!! I actually was define the them as constants and not variables.
