Control Samsung UC6300 LED backlight LCD screen with RS232
We recently moved from using projectors to LCD screens, and the screen of choice was the UC6300, which has a 3.5mm "REMOTE" control input.
Upon using the "easter egg" menu, which I can go in and change the remote control from UART, logic and diagnostic, I left it on the default UART, which I know is not normal serial 232C, however I didnt think logic was the correct item.
After this, I wired a 9pin to 3.5mm cable using the attached diagram.
Attached is some code that doesnt seem to do ANYTHING..
dvTV		= 5001:6:0	// Samsung LCD 55" -- 9600,8,N,1
VOLATILE INTEGER nTvChannels[] =
    526,	// 0
    527, 	// 1
    528,	// 2
    529,	// 3
    530,	// 4
    531,	// 5
    532,	// 6
    533,	// 7
    534,	// 8
    535	// 9
// TV's
DATA_EVENT[dvTV]
    ONLINE:
	WAIT 5
	    SEND_COMMAND dvTV, "'SET BAND 9600,8,N,1 485 DISABLE'"
// LED TV's
BUTTON_EVENT[TPS,520]	// TV 1,2,3 Power Toggle
    PUSH:
	WAIT 9
	    SEND_STRING dvTV, "'P'" //
BUTTON_EVENT[TPS,521]	// TV 1,2,3 Source Change Toggle
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "0,'N',1" //
BUTTON_EVENT[TPS,522]	// TV 1,2,3 Channel up
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "'u'" //
BUTTON_EVENT[TPS,523]	// TV 1,2,3 Channel down
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "'d'" //
BUTTON_EVENT[TPS,524]	// TV 1,2,3 Volume up
    PUSH:
	WAIT 1
	    SEND_STRING dvTV, "'r'" //
BUTTON_EVENT[TPS,525]	// TV 1,2,3 Volume down
    PUSH:
	WAIT 1
	    SEND_STRING dvTV, "'l'" //
BUTTON_EVENT[TPS,nTvChannels]	// TV 1,2,3 Number keys
    PUSH:
	SWITCH( GET_LAST( nTvChannels ))
	    CASE 1:
		WAIT 1
		    SEND_STRING dvTV, "'0'" //
	    CASE 2:
		WAIT 1
		    SEND_STRING dvTV, "'1'" //
	    CASE 3:
		WAIT 1
		    SEND_STRING dvTV, "'2'" //
	    CASE 4:
		WAIT 1
		    SEND_STRING dvTV, "'3'" //
	    CASE 5:
		WAIT 1
		    SEND_STRING dvTV, "'4'" //
	    CASE 6:
		WAIT 1
		    SEND_STRING dvTV, "'5'" //
	    CASE 7:
		WAIT 1
		    SEND_STRING dvTV, "'6'" //
	    CASE 8:
		WAIT 1
		    SEND_STRING dvTV, "'7'" //
	    CASE 9:
		WAIT 1
		    SEND_STRING dvTV, "'8'" //
	    CASE 10:
		WAIT 1
		    SEND_STRING dvTV, "'9'" //
When I press a button, the TX Led lights, however no RX light.. but the cable was tested with a cable testing and it is all correct ~ the cable is about 45 feet long, is this too long for the AMX ?
Any help on this is much appreciated ! :)
-Paul
  • tom goeztom goez Junior Member
    Samsung UC6300
    Change: SEND_COMMAND dvTV, "'SET BAND 9600,8,N,1 485 DISABLE'"
    To: SEND_COMMAND dvTV," 'SET BAUD 9600,8,N,1' "
    I don't know if you did a copy of your code, but BAND should be BAUD... and you don't need the 485 DISABLE part.
  • OHH. .thank you, I did miss that, that was copied directly out of netlinx; I'm suprised it compiled..
    Is there a reason when or when not to have the 'DISABLE 485' ?
    I have always used this just because it is how I saw others.
