MVP-5200i(v2.86.52) and maximum file size
ajish.rajuajish.raju chief evangelist of favante
Here is the known issue with this firmware
•Some large projects that used most of the available RAM will no longer load due to a decrease in available RAM to support the new font rendering engine. This typically results in the panel jumping to the setup pages but sometimes results in a black screen.
What is the maximum file size that can be loaded for this touch panel using this firmware. My current touch panel size is 20 MB
