Air conditioner
Hi everybody.
Anyone knows if there is any air conditioner for 2-3 rooms only that have some way to be controlled in bidirectional way (so i can read status, alarms, errors)? I think BI-DI comm requires some sort of serial port and not just an IR transmitter.
Thank you
Jack
Thank you
Jack
If you're talking split or in-wall/window then I'd say there aren't any in-wall/window that can do it unless it's RF based and while split systems are more likely I don't know of any and I don't even think they're set up for wired T-Stats since they're more of a retrofit product. Of course it would be an easy thing to make provsions for on the indoor unit so it's possible.
The request from a customer is about a conditioner that:
- Is a split with one external unit and two or three internal ones
- Uses "inverter" technology, so power consumption will decrease when internal temp is about to be reached
- Is fully integrated with other domotic interfaces (ie never need to use the remote control, but if somebody uses it, the domotic interface should reflect the settings made by ir).
- It should not be too "big" since the available power for all room is limited to 3 KW.
And i would add a request, if possible i'd like to use a single connection between "server" and conditioner for all rooms.
Since it's my first integration of an air conditioner using amx, i really don't know where to look :-)
PS: I forgot to say, i'm from Italy, so i need to use products available here
Thank you
Jack
