Polycom
Looking for a bit of help and advice in regard to a Pollycom hdx9000 codec, everything is working ok but i am looking for the command to disable/enable the Polycom mic and also when i pick an external camera "'camera near 3',$0D" it picks the camera just fine and lets it switch back to the main camera via camera 1 comand but when i use input 4 for a PC or laptop input "'camera near 4',$0D" although it picks the PC/laptop when external camera or main camera is selected via the above commands these only show the camera in the pip window and do not cancel the PC image, using the content button on the remote seems to cancel the pc image, any help would be greatly appreciated especially in being able to disable and enable the polycom mic.
"'vcbutton play', 13"
"'vcbutton stop',13"
That's my experience, anyway.
I was under the impression that the HDX 9000 codec didn't come with a remote and that if you had the remote it might not work unless you have an add on IR receiver as the codec doesn't have IR capability built in. Do you have the optional remote and IR receiver?
It's the 8000 that doesn't have a built in IR receiver IIRC. The 9000 definitely does, and also does come with a remote.
You are, no doubt, correct. We had an exciting time not too long ago with an HDX codec and it must have been the 8000.
Nope, the cameras do.
