Noob with a couple of questions
Hi,
doing my first NL project and have been plowing through some 1000+ pages of documentation and there are two things I cannot find any information about:
1: How do you configure a master serial port (not the control port), i.e. baud rate, stop bits, etc.?
2: Is there any manual about how you can control a TP via code, i.e. programmatically control states of buttons, page flips, etc.?
Regards
Goran
«1
    GoEk wrote: »
    Hi,
    Regards
    Goran
    Rs232 port settings are controlled by sending the device a Set_baud command. This can be found in the program guide which you can download in the tech section of AMX.com.
    You control button feedback/states by channel_events in code. on[dvTP,1]. Off[dvTP,1]
    here again the programmer guide for the TP HAS all this too.
    E
  • GoEkGoEk Junior Member
    ericmedley wrote: »
    E
    Thanks for your answer. I have checked the Manuals->Developer Tools download section and cannot find a "Programmers Guide". I have a NetLinx Language Reference which has no information at all about the "Set_Baud" command. Can you point me in the right direction?
    http://www.amx.com/techcenter/manuals.asp
    Find the device you're programming and download it there.
    e
    ericmedley wrote: »
    e
    Oh, they are device specific, thanks!
    Goran
    GoEk wrote: »
    Goran
    In a sense. For example, NI-X100s all have the same manual. It's best to go to the device in question and just download the manual for it. Cards for the NI Netlinx master are also in the same manual. So, if you're trying to configure a rs232 card in an NI-4100, the NI-X100 manual probably has what you're looking for.
    ericmedley wrote: »
    OK! Another question, it seems ordinary C typecasts aren't available, so how do you get rid of conversion warnings when you do this:
    String[StringIndex] = Integer + 48;
    Regards
    Goran
  • rfletcherrfletcher Junior Member
    GoEk wrote: »
    Regards
    Goran
    The relevant portion of NetLinx Keywords Help
    TYPE_CAST
    This routine eliminates compiler type cast warnings by casting the passed intrinsic variable type to the type assigned by the return value.
    IntrinsicVariableNewType TYPE_CAST (IntrinsicVariableType)
    It is possible to eliminate the compiler warnings related to type casting.
    The TYPE_CAST library function converts any non-array intrinsic type to any other non-array intrinsic type.
    The type conversion still happens and follows standard type conversion rules, but any warnings related to the type cast are eliminated.
    Note: Type casting causes a potential loss of data when a variable or constant is assigned to a variable of smaller type.
    rfletcher wrote: »
    Oh, there is a type cast available, thanks!
    Anyone that can point me to a tutorial on IR files? Can't find any info on how "it all connects", i.e. the IR file, decvice mapping and the code that gets the IR eye to actually operate.
    Goran
    GoEk wrote: »
    Goran
    These questions and the many more you're likely to run into will be answered when you take the programming classes offered by AMX. Your sales rep can hook you up. This forum is not a good place to come and get 'how to get started' type advice or freebie example code.
    Here's the FAQ section http://www.amxforums.com/showthread.php?4085-Forum-FAQs
    thanks
    e
  • BigsquatchBigsquatch Junior Member
    Also find and download AMX PI if you don't already have it. This contains commands and programming info for just about all AMX devices. Much quicker and easier than finding and downloading device specific documentation everytime you have a question.
    Found it for you:
    http://www.amx.com/products/AMX-PI.asp
    ericmedley wrote: »
    Wow, I am absolutely amased!? I have never, ever on any other peer-to-peer forums I use been met with such an attitude. Then what is is for? I am certainly not asking you to write code "for free" for me if that is your problem, I am merely asking to be pointed in the right direction in the AMX jungle of apps and doc's but if that is too much "freebie" help for you, fine.
    Bigsquatch wrote: »
    Found it for you:
    Thank you for your kind answer!
    GoEk wrote: »
    We veterans of amxforums here for the most part feel that these forums should be for professionals to exchange ideas. There are a lot of DIYers recently that have not even been to AMX training come here asking very, very basic questions and it rubs some of us the wrong way. Knowing this, you should not be surprised if you receive a bristly reception occasionally from one of your 'peers.' Thanks for understanding.
    GoEk wrote: »
    LMAO - you haven't seen any attitude, Eric gave you a very sugar-coated response I'd typically give, but since you didn't receive it so well, here's the harsh reality.
    This is not a DIY forum. This isn't a forum for those who want to dabble with AMX. This forum isn't for end-users, and this forum is definitely not for the guy who has to pay for tech support - there are some dealers who have to. Summary - if you fall into any of those categories, this isn't a forum for you. Try a Yahoo! group.
    Furthermore, I would assume that you do not have a dealer ID but you have admitted to have the software. If you downloaded it directly from the AMX website you would have had to agree to these terms:
    The AMX Software is subject to restrictions on distribution described in this License Agreement. AMX Dealer, Distributor, VIP or other AMX authorized entity shall not, and shall not permit any other person to, disclose, display, loan, publish, transfer (whether by sale, assignment, exchange, gift, operation of law or otherwise), license, sublicense, copy, or otherwise disseminate the AMX Software.
    ACKNOWLEDGEMENT.
    You hereby acknowledge that you are an authorized AMX dealer, distributor, VIP or other AMX authorized entity in good standing and have the right to enter into and be bound by the terms of this Agreement.
    Are you an authorized "AMX dealer, distributor, VIP or other AMX authorized entity"? If so - get some training. If you've got training already, you're a fine example that training at AMX needs to be beefed up some more.
    Admin - will you PLEASE get rid of the DIY'ers, unauthorized members, and end-users? This pollution on the forum is getting very old.
  • the8thstthe8thst Junior Member
    http://www.scribd.com/doc/19533575/Amx-Netlinx-Programming-Ba01
    That should answer all of your getting started questions.
    Thanks! Now we get to suffer through this guys "How do I do...." posts for the next five years.
    mpullin wrote: »
    Thanks for the answer. Just FYI, I am doing my first NL project which happens to be a real world commercial one for a "well known" restaurant chain, not a DIY project. I have a fresh AMX Designer degree and are scheduled for Programmer 1 within a month BUT I do not have time to wait that long before getting started so here I am, somewhat frustrated with the available AMX documentation, there is a lot of "click this to load that"-manuals that are very informative but basically I am lacking a good hands-on tutorial for a real world project.
    Being a fairly experienced C/C++ embedded and windows programmer I have gotten used to being able to ask, and also answer, "noob" questions for a long time on forums, personally I think it adds overall value, to the tools, the community, hence my surprise. If anyone think my questions are to basic, instead of calling me a leech, just don't reply.
    jjames wrote: »
    Unbeleivable....
    GoEk wrote: »
    I really didn't think my response was bristly at all. And there are plenty of Cxx, JAVA, Objective C forums where you'll get thoroughly thrashed about the head and shoulders for being a NOOB. I was just stating a fact about this forum. when I first came on, I was warned by instructors at AMX to keep the NOOB questions to a minimum on the forum. That's not to say that I haven't asked some pretty dumb stuff before.
    So, no offense was intended and it's also not to say that you're not welcome here. Quite the opposite. If you're a serious programmer, you'll find this forum is probably the best place to come for help and advice. I know I do.
    ericmedley wrote: »
    ... when I first came on, I was warned by instructors at AMX to keep the NOOB questions to a minimum on the forum...
    Well, I was not and the fact that AMX representatives have to "warn" new users about their own forums is surreal, why don't they add a noob section to the forum then?
    Lots of the people here are professionals who have put years of work and study to get where they are in AMX proficiency. Sharing techniques to further our business is common here. What is becoming more common of late is a lot of posts from folk who know nothing, got some equipment on ebay, and want someone to explain it to them. This annoys everyone and makes them more ready to snap at anyone,
    It's maybe even worse to know that you have sold your lack of knowledge and experience to a "well known" restaurant chain, the reaction to that by those here is justifiably bitter. Most of the industry is suffering now for a lack of work, and many folk here have lost bids to "noobs" that underbid and get the jobs, then screw it up mightily and come on the forums to ask to be bailed out with (free) advice from the guys who bid fairly per their skills and lost the job, so the noob gets paid, so they can underbid the pro's again... and give the whole industry a reputation for ineptness.
    Lather, rinse, repeat.
    So, please try to understand why there be alligators in these waters.
  • josefinojosefino Junior Member
    Training
    I went to Installer and Programmer I courses, and really those courses scratch the surface specially programming. Those courses give you the basics, and in one week you are not going to know all about AMX programming. Is not like you finish the course and you can write your own code and modules. It takes practice, patience and the will to learn more, but in this forum you will find useful info or the idea to make something work certain way. Many of the gurus from this forum are willing to help; I got some help from them. But really what you asked is a beginner question. What you need the installer and programming manual.
  • viningvining X Member
    GoEk wrote: »
    Unbeleivable....
    Once upon a time a noob would receive a cordial welcome from senior members but apparently we're becoming angry, hostile and less tolerant. Weren't we all noob dumb a$$es at some point too? Thank god the forum was civilized back then.
    Welcome aboard!
  • I think John Nagy's post sums it up pretty well really.
    I also agree with JN's post but it's a catch 22. AMX requires new dealers to sell systems despite the fact that they aren't qualified yet which is great for companies that sell configurable software solutions. So a lot of companies who go this route never really become qualified since they just copy and paste in the config parameters needed to set up the system using the software they buy which is fine for folks who don't want to invest the time that's required to do it themselves. For the most part they're probably better systems too.
    The only experienced dealers who loose bids to noobs are those typically commercial accounts that know what they want and invite AMX dealers to bid the job becasue they already know they want AMX but with most jobs the customer has never heard of AMX and the one who bids the job is the one that introduces AMX to the client. They may have other bidders suggesting Craptron or some other less capable systems. So in most cases the noobs are generating revenue for AMX where otherwise there would be none.
    Now if a client knows they want AMX and sends out bid request to regional dealers and they get back bids from experienced dealers and low balling noob dealers and they decide to go with the noob despite your proposal that outlines your experience and expertise there's a good chance lossing the bid was a blessing in disguise and not the type of job you'd want anyway. Most good clients never go with the lowest price because they know what that may get them and noobs don't have the referrals or the list of accomplishments that the experience dealers have. So if you loose the job to a noob your likely better off.
    Dealers have to start somewhere and if we're to support AMX we also have to support the noobs which to some extent are the future of AMX.
  • AuserAuser Junior Member
    vining wrote: »
    Once upon a time a noob would receive a cordial welcome from senior members but apparently we're becoming angry, hostile and less tolerant. Weren't we all noob dumb a$$es at some point too? [...]
    Welcome aboard!
    Here here.
    Not all noobs work for trunk slammers either. It's just a pity more don't read the forum FAQs - I wonder if there's a way to make them a sticky at the top level?
    And a FAQ about reading AMX documentation and where to find it would be nice. Kudos to the OP though - at least he's tried to find the answer in the documentation for himself before asking for help.
    I think there's a distinction to be made. I have zero issues with a noob.
    A noob question is something like, "I was handed the AMX laptop and sent to class but cannot even remember how to click a dang relay. help?"
    As we all have seen, many new posters have come asking things like, "I have an NI-3000 and a stack of gear. Can someone post me the code and a nice TP design? Our living room is done up in greens and I like sports images."
    The OP was obviously not the latter. I too welcome you to the forum. It's a great resource. I honestly think it's the best place to come.
    If you don't like noob questions, why are you clicking a thread labeled "noob questions"? This is not an e-mail list, these threads are not polluting your inbox or using up anything other than a 40 pixel high row of your screen on the "New Posts" page.
    GoEk, Eric's response was simply stating that the best use of your time is to go to AMX training. You're never going to learn all the little pieces from the forums, and it's very difficult to get the big picture from the piles of documentation. The docs are meant as reference for people who already learned this stuff once, not tutorials.
  • thepainterthepainter Junior Member
    vining wrote: »
    ............ Weren't we all noob dumb a$$es at some point too? Thank god the forum was civilized back then.
    Welcome aboard!
    Well said Vining, I actually have been helped tremendously here in the forums but sometimes don't ask certain questions for fear it might be categorized as AMX 101. The best case scenerio would be to know someone in your area who is willing to be a mentor and maybe not do the code for you but point you in the right direction with some helpful tips and in all honesty it sometimes is just a case of 'if it was a snake...' and a gentle push in the right direction was all it took.............. anyone in the Ft. Lauderdale area? :)
