access code to TP page
HI ALL
i need to make login button to TP page this button didnot flip to the secured page without entering the right pin code.
please help
  • ericmedley
    You can do it in either TPbDesign by making the button do a page flip and then setting that button's security settling to ask for a password or perform thevfunction from code.
  • kfahmy
    kfahmy Junior Member
    is this the code do the required function??
    DEFINE_START
    CREATE_BUFFER TP1, TP1_BUFFER
    DEFINE_EVENT
    DATA_EVENT[TP1](* EVALUATE TP1 DATA *)
    STRING:
    SELECT
    ACTIVE (FIND_STRING (DATA.TEXT,'PAGE-',1)):
    JUNK = REMOVE_STRING (DATA.TEXT,'PAGE-',1)
    CUR_PAGE = DATA.TEXT
    ACTIVE (FIND_STRING (DATA.TEXT,'KEYP-',1)):
    xxxx (* keypad code *)
    ACTIVE (FIND_STRING (DATA.TEXT,'KEYB-',1)):
    1234 (* keyboard code *)
    ACTIVE (1):
    1988 (* default code *)
    CLEAR_BUFFER TP1_BUFFER
    ONLINE:
    SEND_COMMAND TP1, 'TPAGEON'
  • ericmedley
    This code will get you the current page or whether or not the user has entered a strung from either the keyboard or key pad.. You still need some code to do something with that information. It's pretty basic string parsing, however.
