Zigbee Gateway IP Adress
davegrovdavegrov Junior Member
Finally have some time to play with my Demo R4 I bought last year. I started by taking the Zigbee Gateway out of the box and putting it on my network. I run Zero Config and I get an IP address of 72.3.199.7. Try to enter the unit through Netlinx and IE9 (Compatibility turned ON) and get no luck. Tried several factory resets with no luck.
Any Ideas, thoughts or is it a bad unit?
Thanks in advance
David Groves
ACE
  • viningvining X Member
    What subnet is your PC on? Does the Zero Config Utility allow you to set the gateway's IP? (I've never used it) If so set it to a address on your PC's and Master's subnet. If zero config doesn't allow you to set the gateway's IP you'll have to change the IP of your PC to a static address in the gateways subnet. Connect, set the IP of the gateway and then reset your PC back to DHCP so it goes back to its previous address.
  • davegrovdavegrov Junior Member
    Subnet 255.255.255.255.0
    I tried changing the IP address of my PC to the same one except the last number of the octet and when I did that Windows set 255.0.0.0 subnet for me. I've used a similar procedure when setting up the new WAP's and the Zone Director. No luck here.
    My hunch is that this Gateway is for use in a country other than the USA.
    I just let them get a DHCP address then look for their MAC in my router's client table.
    Thank You
    Turnip Truck,
    Thank You. That approach worked. Wish I had though about it myself. One more trick in the toolbag.
