IO Port Output as 12V Trigger
sonnysonny Junior Member
Anyone ever used an IO Output as a 12V trigger, I've used these for inputs a number of times, but I'm out of relays on the processor and need a couple of outputs. If I read correctly, the pins are shorted to ground when the channel is turned on in the processor. When I turn on I can measure 12V between the output and the 12V connection, but when off I get 8V. I'm guessing this is due to it being a solid state output. The problem is when I plug into the Amp, the channel gets turned on, apparently reading this as an input??
Do I have to backend with a relay to make this work?
Thanks, Sonny
