Level back and forth
I've been trying to find a better way program two-way level control, by which I mean that the same bargraph can send a level and display the feedback value.
I have it working with a Vantage lighting system, and when I started I found it possible to put the lighting system into a loop. The feedback would be a little behind the level out, so the bargraph would change to the feedback value under your finger, and then send that value out again, etc etc.
I got around it by disabling feedback from the lighting system based on the push of the bargraph, and then updating it on the release, but it seems like a clunky solution.
Anyone have any alternatives?
$P provides a text version of the bargraph level, right? I'm not sure how that would help. Could you elaborate? Thanks
I guess I just don't understand exactly the issue or what you're trying to do. Are you trying to do 100%-real-time levels?
And the issue I'm having is (I believe) that the level going out is always going to be a bit higher than the level coming in from the lighting system; and that's caused the lights to loop and flash between the new level and the lower feedback level. So while defeating feedback while dragging seems to have worked, it seems a clunky workaround.
If you tell Vantage to discretely go to 20%, then 21%, then 22, then 23, etc. - it will go 20-21-22-23, etc. If you tell it to go 25, 40, 45, 21, 90 wouldn't it do it? I think the problem is the perception of real time based on how long the lights actually take to get to said percent. Either way - Vantage *SHOULD* end up on the last sent level. The problem you will probably have is how quickly it can receive the strings . . .
For volume bargraphs (not all that different than lighting bargraphs), I keep track of the level myself and what is display is what was sent out last. Of course, when entering the page - you may want to query it's value.
Cheers.
Also add a channel port and channel to your invisible "touching" bargraph and set a tracking channel or var on push, unset on release. Use this to prove your level event form the bargraph. If no push, no level change so that panels falling off line don't send a level value of zero to your lighting system.
Got an amp, polling it in case someone changes volume on front panel. On setting the volume of the amp, it also responds with the current level of the volume which is the same as polling response so...
Send level to vdvAmp > vdvAmp sends volume change code to dvAmp > dvAmp responds with new volume > Send level with new volume to vdvAmp level for feedback.... does this then trigger the level event for vdvAmp again?
I think that makes sense.
I would still change the code to break that loop.
As Vining says, a level_event won't get triggered if its already at that level, which it will be since you sent the value to the virtual when you parsed it from the amp. Same thing with channel events which can sometimes be annoying when you want to update a panel coming online but that's fine. I see no reason to change working code that is engineered correctly like Vining would, but I'm lazy.
Paul
I have no problem sending a level to a dev in one direction on every pass of the mainline since I know it willonly be sent once but the back and forth action seems wrong, they shouldn't trigger events that way. Each direction should be single ended.
I'm giving him the benefit of the doubt that he programmed it thinking it should work that way but wanted to be sure and asked here. Either way, I don't change good code regardless of whether skill or luck was the method used to create it.
I don't think that's what he is doing. My understanding of the event table is this:
dvTP --> vdvDev --> dvDev --> vdvDev --> dvTP.
I'm not seeing anything wrong with this design at all. Perhaps you are doing something other than this and having problems.
Any mistake in any code can have deleterious effects on things. That's why I try not to make any.
Mainline can introduce timing issues with events which could possibly cause problems, and I wonder if that is what you were seeing.
Paul
FYI, what I was reffrering to with my level looping issues was a long time ago an don't recall what the circumstances were and as far as my comment on level feedback in DEF_PROG that was just to illustrate that since the master tracks levels like it does channels it's not he end of the world or for that matter the end of the master. It's not the greatest thing to do but it is doable with out any significant ill affects on a typical system. I personally don't like to do it as a general rule but I'm not going to put someone down who does. Hopefully in time they'll change but if not god bless them anyway.
