some tp4 questions
udiudi Junior Member
How can I show the battery description of the iPad and the reception in the TP4?
To show the battery description I tried to change to setup port but there are some options and I don’t know what to choose and what is the different between the parameters.
Another question can I reverse the dragging of the bargraph button? Meaning if it is from down to up I want it to be from up to down.
Thanks for any help.
    udi wrote: »
    AFAIK there is no way to show battery life and wireless connection strength on the iPad with TPC.
    udi wrote: »
    Try the Range Inverted property on the Programming tab of the bargraph and see if that gets you what you're looking for.
