AXIS point
I want to use an IPad and IPod for the AMX controler.
Can someone tell me which AXIS point is recomended for them???
thanks.
thanks.
I'd recommend a Cisco or Ruckus. I'd also HIGHLY recommend using a managed wireless system. iPads are notoriously flaky when it comes to wireless. A managed WAP system does a wonderful job of actively keeping those devices online.
Runkus's system is pretty cost effective. Zone Drector 1000 or 3000
Cisco's is much more expensive but pretty bullet-proof.
By the way, my iPad is rock solid with great range on my current home nasty cheapo not-recommended Netgear $30 router. So notorious as they might be, your mileage is almost sure to vary.
SonicWall seems to be the most universally-hated product line amongst IT types inside and outside of the control system world. I would avoid it.
I have not had good luck with the built in wireless on the sonicwall TZ series firewalls, but everything else has been rock solid. What is so hated about Sonicwall?
I have used pakedge a couple of times and have not been impressed with them for their price point. For really inexpensive (read not AMX jobs) the Engenius stuff has been pretty nice with good range and fast throughput.
I have been meaning to order an Ubiquiti Picostation for the low end price points. I have heard they have great range and are very reliable.
I'm curious as to this too as I've not had any serious problems with the one we use in the office.
"Same story, different version. And all are true." - Diadoma in 'Pirates of the Carribean - Dead Man's Chest'
Another high quality product is Mikrotek. They make some really powerful gear too.
Thank all for your recommendations.
I am looking for solution to residentialand & houses.
I believe the average wifi products: Netgear, Linksys, Dlink and etc… will do the work,
But I am looking stability.
What products and models would you recommend to use sized penthouse apartment of 300 square meters?
I have a Netgear WGR619v9 router/WAP at my house. I think it was under $50 and it's been up and running for at least two years without any problems whatsoever. I am quite sure it would work for your apartment. You just won't be able to create VLANs, VPNs, and do more advanced firewall stuff that comes with more advanced routers.
It seems to me that I have less problems with the el cheapo stuff than I have had with the more expensive "Good Stuff."
We now use Watchguard xtm products, HP procurve switches and waps
If you're doing voip on TPs you nead a managed system to handle the handoffs or you'll have dropped calls while walking/talking so Cisco, Rukus, etc are needed. I still on ocassion use Linksys WAP54g (mostly past tense) which are hated by most here but I really don't have problems with them. On occassion they will lock up but that's the price you pay to get a job with in budget and I can't say that the better APs don't on occasion either, it's rare regardless. If it's a choice between a good access points and a VPN router I'll go the way of the VPN router. If it's a choice between good access point and remote power management I'll go for the remote power management and then be able to remotely reboot my APs.
As far as the Penthouse apartment goes how many APs are needed depends on where your wireless TPs will be, where you can stick APs and what types of wall construction you're dealing with. If the walls are just sheetrock on metal studs that's not a big problem but if they are concrete or tiled then that is. If you have access to the apartment do a site survey with any off the shelf AP using wi-spy.
Watchgaurd looked interesting when I looked into it, but the company already had a few Sonicwalls in the field so I stuck with that.
How are the ProCurve WAPs working out for you? We used them for awhile, but I was never impressed with their range and we could never get 5200s to be very reliable with them.
I have 3 or 4 MSM310 indoor Procurve waps that we replaced with Ruckus systems that I will sell to you for cheap. Send me a PM if you're interested.
The unifi units look very interesting, no h/w manager needed. I've just ordered 3 to test out
not for me thanks :-)
Keep in mind that the Unifi system needs a computer on the network 24/7 to run the software that would normally be handled by a hardware controller.
Take a look at http://www.aerohive.com/ if you are truly looking for a managed wireless system without needing a controller.
Always like testing these things before needing or wanting to use in anger.
I have not tested either one.
I spent some time researching managed wireless systems a while ago when we were having all of the problems with the HP WAPs. My short list included Ruckus and Aerohive. Ubiquiti would have been on the list if they had a hardware piece to run the manager software. That was just as AMX announced the partnership with Ruckus (which was at the top of my list), so I stopped looking and just started using the AMX branded Ruckus products.
I think Ubiquiti is researching some small form factor ATOM based components to use so they can offer a controller for the UniFi access points. The forums on their website are pretty active and have a lot of good information.
All-in-all I have been very happy with the performance and stability of the AMX/Ruckus systems. I just have to decided on a budget system with 1 or 2 inexpensive access points (probably Ubiquiti PicoStation).
